Help understandin how my flake.nix should be for a python project
I have a project that will create some bindings for a library called testProject here.
Running nix develop is fine.
Running nix build is also fine.
but when trying pip install . I get errors about missing dependencies.
I thought maybe creating a new development shell with a virtual environment that I start like this nix develop .#pyenv and installing manually my dependencies with be a good idea.
But is this the best way of doing things?
Or is there a better way to use the dependencies that I already got with nix, to be used when I try to also build my python project?
dependencies.sh
if [[ -n "${VIRTUAL_ENV}" ]]; then
    INSTALL_PREFIX="${VIRTUAL_ENV}"
elif [[ -n "${CONDA_PREFIX}" ]]; then
    INSTALL_PREFIX="${CONDA_PREFIX}"
else
    INSTALL_PREFIX=$(python -c "import sysconfig; print(sysconfig.get_config_var('prefix'))")
fi
if [[ -z "${INSTALL_PREFIX}" ]]; then
    echo "Error: could not determine install prefix."
    echo $INSTALL_PREFIX
    exit
fi
set -e
PLATFORM=linux
if [[ "$OSTYPE" == "darwin"* ]]; then
    PLATFORM=osx
fi
# openlibm
git clone https://github.com/JuliaMath/openlibm.git
pushd openlibm
git checkout c4667caea25ae3487adf6760b4a1dcf32477a4b8
mkdir build
cmake -S . -B build \
   -DCMAKE_BUILD_TYPE=Release \
   -DCMAKE_INSTALL_PREFIX=${INSTALL_PREFIX} \
   -DBUILD_SHARED_LIBS=OFF \
   -DCMAKE_INSTALL_LIBDIR=lib \
   -DCMAKE_INSTALL_INCLUDEDIR=include \
   -DCMAKE_POSITION_INDEPENDENT_CODE=ON \
   -DCMAKE_PREFIX_PATH=${INSTALL_PREFIX} \
   -DOPENLIBM_ENABLE_TESTS=OFF
cmake --build build -j
cmake --install build
popd
rm -rf openlibm
flakes.nix
  description = "My development environment";
    mypackages.url = "github:mypackages/nur-packages";
    nixpkgs.url = "github:nixos/nixpkgs/master";
    testProject.url = "github:mypackages/test-project";
    mypackages.inputs.nixpkgs.follows = "nixpkgs";
    testProject.inputs.nixpkgs.follows = "nixpkgs";
  outputs = inputs@{ self, flake-parts, nixpkgs, mypackages, testProject }:
    flake-parts.lib.mkFlake { inherit inputs; } {
      systems = [ "x86_64-linux" "aarch64-darwin" ];
      perSystem = { pkgs, system, ... }:
          pkgs = import nixpkgs {
            inherit system;
            overlays = [
              mypackages.overlay
              (final: prev: {
          enableShared = false;
          stdenv_ = pkgs.llvmPackages_18.stdenv;
          python_ = pkgs.python312;
          venvDir = ".venv";
          testProject_ = if enableShared then testProject.packages.${system}.library else testProject.packages.${system}.library-static;
          pyforge = stdenv_.mkDerivation {
            name = "pyforge";
            src = self;
            cmakeFlags = [
              "--preset ${if pkgs.stdenv.hostPlatform.isx86_64 then "build-linux" else "build-osx"}"
            cmakeBuildType = "Debug";
            dontStrip = true;
              clang-tools_18
              cmake
              ninja
              pkg-config
              python_
              python_.pkgs.pybind11
            buildInputs = with pkgs; [
              (python_.withPackages (ps: with ps; [ setuptools wheel requests ]))
              testProject_
            ] ++ testProject_.buildInputs;
            propagatedBuildInputs = with pkgs.python312Packages; [
                scikit-build
                pybind11
                # Add other Python dependencies here
        rec {
          packages = {
            default = pyforge;
            pyforge-generic = pyforge.overrideAttrs (old: {
              cmakeFlags = [
                "-DCMAKE_BUILD_TYPE=Release"
                "-DCMAKE_CXX_FLAGS=${
                  if pkgs.hostPlatform.isx86_64 then "-march=x86-64" else ""
            pyforge-debug = pyforge.overrideAttrs
              (old: { cmakeBuildType = "Debug"; });
          devShells.default = stdenv_.mkDerivation {
            name = "pyforge-dev";
            nativeBuildInputs = pyforge.nativeBuildInputs;
            buildInputs = pyforge.buildInputs;
            shellHook = ''
              export SHELL=/run/current-system/sw/bin/bash
              # Virtual environment setup
                if [ ! -d "${venvDir}" ]; then
                  echo "Creating virtual environment in ${venvDir}"
                  ${python_.interpreter} -m venv ${venvDir}
                fi
                source ${venvDir}/bin/activate
                # Allow pip to install wheels
                unset SOURCE_DATE_EPOCH
                # Install development dependencies if requirements-dev.txt exists
                if [ -f requirements-dev.txt ]; then
                  pip install -r requirements-dev.txt
                fi
          devShells.pyenv = stdenv_.mkDerivation {
              ++ (with pkgs; [ gdb valgrind gcc13 ])
              ++ (with python_.pkgs; [ scikit-build ]) # cmake integration and release preparation
              ++ (with python_.pkgs; [ numpy scikit-learn pandas pyarrow ipdb sympy requests matplotlib optuna jax jaxlib-bin torch ])
              ++ (with pkgs; [ (pmlb.override { pythonPackages = pkgs.python312Packages; }) ]);
            shellHook = ''
                fi
                # Install all Python dependencies via pip if needed
                if [ -f requirements.txt ]; then
                  pip install -r requirements.txt
                fi
                # Install development dependencies if they exist
                fi
Also after running nix develop and python, I get:
import sympy
File “”, line 1, in
ModuleNotFoundError: No module named ‘sympy’
But since sympy was listed in my buildInputs, I would have thought I can use it.
