Hello, I haven’t created a minimal version of my problem for fear of hosing my system but I believe this is sufficient (because I feel that the problem is something simple and fundamental I’m missing, please do let me know if I should give a full configuration.nix
If I put the following inside a let on top of my configuration.nix and proceed to use productVersion
in the inside in
block …
productVersionCommand = "${pkgs.coreutils}/bin/cat /sys/class/dmi/id/product_version";
# productVersionFile =
# builtins.trace
# "productVersionFileReturnedHere"
# pkgs.runCommand
# "product-version"
# "${productVersionCommand} > $out"
# productVersion = builtins.trace "productVersion" ( builtins.readFile productVersionFile );
# productVersion = builtins.trace productVersionFile "ThinkCentre M93p\n";
productVersion = builtins.trace productVersionCommand "ThinkCentre M93p\n";
# productVersion = builtins.readFile /sys/class/dmi/id/product_version;
# productVersion = "ThinkCentre M93p\n";
…, I get an error- error: infinite recursion encountered, at /nix/var/nix/profiles/per-user/root/channels/nixos/lib/modules.nix:163:28 (use '--show-trace' to show detailed location information)
. From the outputs and commenting-uncommenting some of the included lines- it seems that the issue is with productVersionCommand
evaluation. Would someone be able to help me understand why I’m getting this error? (And if possible- a way to get the output of /sys/class/dmi/id/product_version
in my configuration?)
I have another question if it’s alright to ask here- if my understanding is correct then the hash of a realized store path depends only on the .drv
and nothing else. Is that correct? If so, will this same derivation give, on two different computers, a store path which is same but has different contents?
