Hi i want to use the unstable version of networkmanager on my 19.03 release. I added the unstable channel and did the following
{ config, lib, pkgs, ... }:
baseconfig = { allowUnfree = true; };
unstable = import <unstable> { config= baseconfig; };
imports =
<unstable/nixos/modules/services/networking/networkmanager.nix>
disabledModules = [ "services/networking/networkmanager.nix" ];
nixpkgs.config = baseconfig // {
packageOverrides = pkgs: {
networkmanager = unstable.networkmanager;
but it explodes when i try to nixos-rebuild switch
[99/249] Generating Tracker_C-2.0.gir with a custom command.
g-ir-scanner: link: gcc -o /build/tracker-2.1.8/build/tmp-introspectq804rl9b/Tracker_C-2.0 /build/tracker-2.1.8/build/tmp-introspectq804rl9b/Tracker_C-2.0.o -L. -Wl,-rpath,. -Wl,--no-as-needed -L/build/tracker-2.1.8/build/src/libtracker-sparql-backend -Wl,-rpath,/build/tracker-2.1.8/build/src/libtracker-sparql-backend -L/build/tracker-2.1.8/build/src/libtracker-sparql -Wl,-rpath,/build/tracker-2.1.8/build/src/libtracker-sparql -L/build/tracker-2.1.8/build/src/libtracker-common -Wl,-rpath,/build/tracker-2.1.8/build/src/libtracker-common -L/build/tracker-2.1.8/build/src/libtracker-remote -Wl,-rpath,/build/tracker-2.1.8/build/src/libtracker-remote -L/build/tracker-2.1.8/build/src/libtracker-bus -Wl,-rpath,/build/tracker-2.1.8/build/src/libtracker-bus -L/build/tracker-2.1.8/build/src/libtracker-direct -Wl,-rpath,/build/tracker-2.1.8/build/src/libtracker-direct -L/build/tracker-2.1.8/build/src/libtracker-data -Wl,-rpath,/build/tracker-2.1.8/build/src/libtracker-data -L/build/tracker-2.1.8/build/src/gvdb -Wl,-rpath,/build/tracker-2.1.8/build/src/gvdb -L/nix/store/vfbzpdwyiy0ygmc92af0zgj3m0s6shaw-glib-2.58.2/lib -Wl,-rpath,/nix/store/vfbzpdwyiy0ygmc92af0zgj3m0s6shaw-glib-2.58.2/lib -L/nix/store/ybscfsidg60dnc6gc3vp325xvnqp49za-libxml2-2.9.9/lib -Wl,-rpath,/nix/store/ybscfsidg60dnc6gc3vp325xvnqp49za-libxml2-2.9.9/lib -L/build/tracker-2.1.8/build/src/libtracker-sparql -Wl,-rpath,/build/tracker-2.1.8/build/src/libtracker-sparql -L/build/tracker-2.1.8/build/src/libtracker-common -Wl,-rpath,/build/tracker-2.1.8/build/src/libtracker-common -L/build/tracker-2.1.8/build/src/libtracker-remote -Wl,-rpath,/build/tracker-2.1.8/build/src/libtracker-remote -L/build/tracker-2.1.8/build/src/libtracker-bus -Wl,-rpath,/build/tracker-2.1.8/build/src/libtracker-bus -L/build/tracker-2.1.8/build/src/libtracker-direct -Wl,-rpath,/build/tracker-2.1.8/build/src/libtracker-direct -L/build/tracker-2.1.8/build/src/libtracker-data -Wl,-rpath,/build/tracker-2.1.8/build/src/libtracker-data -L/build/tracker-2.1.8/build/src/gvdb -Wl,-rpath,/build/tracker-2.1.8/build/src/gvdb -L/nix/store/vfbzpdwyiy0ygmc92af0zgj3m0s6shaw-glib-2.58.2/lib -Wl,-rpath,/nix/store/vfbzpdwyiy0ygmc92af0zgj3m0s6shaw-glib-2.58.2/lib -L/nix/store/ybscfsidg60dnc6gc3vp325xvnqp49za-libxml2-2.9.9/lib -Wl,-rpath,/nix/store/ybscfsidg60dnc6gc3vp325xvnqp49za-libxml2-2.9.9/lib -L/build/tracker-2.1.8/build/src/libtracker-sparql-backend -Wl,-rpath,/build/tracker-2.1.8/build/src/libtracker-sparql-backend -L/nix/store/vfbzpdwyiy0ygmc92af0zgj3m0s6shaw-glib-2.58.2/lib -Wl,-rpath,/nix/store/vfbzpdwyiy0ygmc92af0zgj3m0s6shaw-glib-2.58.2/lib -L/nix/store/xbx18r163cbd6jxfv0hcs1r1s5lgz2y7-json-glib-1.4.4/lib -Wl,-rpath,/nix/store/xbx18r163cbd6jxfv0hcs1r1s5lgz2y7-json-glib-1.4.4/lib -L/nix/store/cms59b8gnq1kh6kfxjvrf86xvr81q215-libsoup-2.64.2/lib -Wl,-rpath,/nix/store/cms59b8gnq1kh6kfxjvrf86xvr81q215-libsoup-2.64.2/lib -L/nix/store/ybscfsidg60dnc6gc3vp325xvnqp49za-libxml2-2.9.9/lib -Wl,-rpath,/nix/store/ybscfsidg60dnc6gc3vp325xvnqp49za-libxml2-2.9.9/lib -ltracker-sparql-2.0 -ltracker-sparql-2.0 -lglib-2.0 -lgio-2.0 -lgobject-2.0 -lm -lstemmer -ljson-glib-1.0 -lsoup-2.4 -lxml2 -L/nix/store/vfbzpdwyiy0ygmc92af0zgj3m0s6shaw-glib-2.58.2/lib -lgio-2.0 -lgobject-2.0 -Wl,--export-dynamic -lgmodule-2.0 -pthread -lglib-2.0
src/libtracker-sparql/tracker-namespace-manager.c:335: Warning: Tracker_C: tracker_namespace_manager_foreach: argument func: Missing (scope) annotation for callback without GDestroyNotify (valid: call, async)
./Tools/TestWebKitAPI/Tests/WebKitGLib/resources/generate-test-cert.sh: interpreter directive changed from "/bin/sh" to "/nix/store/cinw572b38aln37glr0zb8lxwrgaffl4-bash-4.4-p23/bin/sh"
autoreconf: running: /nix/store/xf963939s0zvpz1v8fzhh6gr4k37ikqm-autoconf-2.69/bin/autoheader --force
./Tools/gtkdoc/generate-gtkdoc: interpreter directive changed from "/usr/bin/env python" to "/nix/store/9kigl3bk51mfn0484y72w3zlm7d8ws76-python-2.7.16/bin/python"
./Tools/glib/generate-inspector-gresource-manifest.py: interpreter directive changed from "/usr/bin/env python" to "/nix/store/9kigl3bk51mfn0484y72w3zlm7d8ws76-python-2.7.16/bin/python"
./Tools/gtk/install-dependencies: interpreter directive changed from "/usr/bin/env bash" to "/nix/store/cinw572b38aln37glr0zb8lxwrgaffl4-bash-4.4-p23/bin/bash"
./Source/WebKit/Scripts/process-entitlements.sh: interpreter directive changed from "/bin/bash" to "/nix/store/cinw572b38aln37glr0zb8lxwrgaffl4-bash-4.4-p23/bin/bash"
./Source/WebKit/Scripts/generate-unified-sources.sh: interpreter directive changed from "/bin/sh" to "/nix/store/cinw572b38aln37glr0zb8lxwrgaffl4-bash-4.4-p23/bin/sh"
[100/249] Generating tracker-sparql-gir with a meson_exe.py custom command.
FAILED: src/libtracker-sparql-backend/Tracker-2.0.gir
/nix/store/0mz0dr57n65fdrzlxjm8sjl7acjf9kzh-meson-0.49.1/bin/meson --internal exe /build/tracker-2.1.8/build/meson-private/meson_exe_g-ir-merge_e772c1fc76fc49dbab9fb1f3b737cd1a11e34dbc.dat
File "/nix/store/0mz0dr57n65fdrzlxjm8sjl7acjf9kzh-meson-0.49.1/bin/meson", line 11, in <module>
sys.exit(main())
File "/nix/store/0mz0dr57n65fdrzlxjm8sjl7acjf9kzh-meson-0.49.1/lib/python3.7/site-packages/mesonbuild/mesonmain.py", line 209, in main
return run(sys.argv[1:], launcher)
File "/nix/store/0mz0dr57n65fdrzlxjm8sjl7acjf9kzh-meson-0.49.1/lib/python3.7/site-packages/mesonbuild/mesonmain.py", line 198, in run
return run_script_command(args[1], args[2:])
File "/nix/store/0mz0dr57n65fdrzlxjm8sjl7acjf9kzh-meson-0.49.1/lib/python3.7/site-packages/mesonbuild/mesonmain.py", line 146, in run_script_command
return module.run(script_args)
File "/nix/store/0mz0dr57n65fdrzlxjm8sjl7acjf9kzh-meson-0.49.1/lib/python3.7/site-packages/mesonbuild/scripts/meson_exe.py", line 99, in run
return run_exe(exe)
File "/nix/store/0mz0dr57n65fdrzlxjm8sjl7acjf9kzh-meson-0.49.1/lib/python3.7/site-packages/mesonbuild/scripts/meson_exe.py", line 79, in run_exe
stderr=subprocess.PIPE)
File "/nix/store/0n8slcq8p5x31kc9hncabsqq9y3fpkzp-python3-3.7.3/lib/python3.7/subprocess.py", line 775, in __init__
restore_signals, start_new_session)
File "/nix/store/0n8slcq8p5x31kc9hncabsqq9y3fpkzp-python3-3.7.3/lib/python3.7/subprocess.py", line 1522, in _execute_child
raise child_exception_type(errno_num, err_msg, err_filename)
FileNotFoundError: [Errno 2] No such file or directory: '/build/tracker-2.1.8/utils/g-ir-merge/g-ir-merge': '/build/tracker-2.1.8/utils/g-ir-merge/g-ir-merge'
ninja: build stopped: subcommand failed.
./Source/WebKit/Scripts/check-xcfilelists.sh: interpreter directive changed from "/bin/sh" to "/nix/store/cinw572b38aln37glr0zb8lxwrgaffl4-bash-4.4-p23/bin/sh"
builder for '/nix/store/isxq1rkakp11w282i6wz3dkylxd071pj-tracker-2.1.8.drv' failed with exit code 1
cannot build derivation '/nix/store/b2nwa3d7pwv5dbrwkclay8fnnm36jlqz-dbus-1.drv': 1 dependencies couldn't be built
cannot build derivation '/nix/store/d663ld3zqnadjx8kgs38y67p4bkld94m-nautilus-3.30.5.drv': 1 dependencies couldn't be built
cannot build derivation '/nix/store/xdvdyzp1y0czf88jc2kiqihkwi039dls-system-path.drv': 1 dependencies couldn't be built
cannot build derivation '/nix/store/3fy5vr7m342g3fkbc8lwq2z5zyzxy40h-system-units.drv': 1 dependencies couldn't be built
cannot build derivation '/nix/store/59h3fbd8pbv2l8nik875njqlhkyrspq2-user-units.drv': 1 dependencies couldn't be built
cannot build derivation '/nix/store/5lxccfk3bkxhhyxvbhygbj4y6wm59vwi-nixos-system-ford-19.03.172500.aade6ded796.drv': 1 dependencies couldn't be built
error: build of '/nix/store/5lxccfk3bkxhhyxvbhygbj4y6wm59vwi-nixos-system-ford-19.03.172500.aade6ded796.drv' failed
any ideas on how to get around this?
