I created https://builtwithnix.org/ a while ago. The idea is to get a new entry-point for visitors coming just for Nix.
To encourage the adoption of the site I also created a badge that can be added to project’s READMEs: . In exchange the site would present good information on how to install Nix and get started.
Tweag also hired a design company to make it look better and after multiple iterations, here is what we came up with (see below).
I am looking for some help to improve the content of the side and to cut the design back into HTML. To participate, ping me here or on IRC.
Defining the audience here is most important, as it will limit the scope of the site. Currently it’s trying to convince the reader that Nix comes with batteries included and is production ready.
I wish we tracked these clicks, because I’m sure many people just fail to try Nix as noone knows they have to press “Get Nix” button twice. My recommendation would be to say it supports macOS and Linux and just provide the snippet to install Nix.
Projects built with Nix
This seems like it should be flipped, listing projects that do use Nix and then a small text to invite folks to add it and instructions should point to a repo markdown file or something
Get started
This one is reaaaally tricky. There are so many ways to start (expression language, basic tooling, packaging for your language X, install NixOS, etc). Most probably it would be best to just provide links for each of those.
nix is a software build tool that works across languages and creates reliable builds.
I love that it doesn’t mention functional languages. It’s an implementation detail for the curious few.
Another generally accessible positive point about nix is that it can incorporate all your projects dependencies, not just the ones of your primary language:
“The polyglot package manager”
“Package management without borders”
“Package management across boundaries”
I think it’s a good initiative. On the other hand, the colors don’t match (it’s a personal opinion). Why not respect the garphic charter of nixos.org? It is simple but effective.
According to the designers the color scheme is a bit dated and wanted to refresh it. I am just a developer so I don’t know anything about colors. It might be a bad idea, or we might just grow used to it.
