Hello All,
I am trying to package pangolin for nix, and i’m getting stuck on the last part.
i am looking at the dockerfile for inspiration but i believe something is going wrong with the copying paths.
pkgs/by-name/fo/fossorial/frontend.nix
installPhase = ''
runHook preInstall
mkdir -p $out/.next/
cp package.json package-lock.json $out/
cp -r .next/standalone/ $out/
cp -r .next/standalone/.next $out/
cp -r .next/static $out/.next/static
cp -r dist $out/dist
cp -r init $out/dist/init
cp server/db/names.json $out/dist/names.json
cp -r public $out/public
cp -r node_modules $out/
runHook postInstall
nixos/modules/services/networking/fossorial.nix
systemd.services.fossorial = {
description = "Fossorial Service";
after = [ "network.target" ];
environment = {
NODE_OPTIONS = "enable-source-maps";
NODE_ENV = "development";
ENVIRONMENT= "prod";
serviceConfig = {
User = "fossorial";
Group = "fossorial";
GuessMainPID = true;
WorkingDirectory = cfg.dataDir;
UMask = 7;
ExecStartPre = utils.escapeSystemdExecArgs [
(lib.getExe pkgs.nodejs_22)
"${pkgs.fossorial}/dist/migrations.mjs"
ExecStart = utils.escapeSystemdExecArgs [
"${pkgs.fossorial}/dist/server.mjs"
–>> link to my fork for full config files if more context is needed
anyone have any idea why i cant find the production build?
journalctl -eu fossorial
gives
node[287186]: 2025-04-23T09:51:04.609Z [warn]: Email SMTP configuration is missing. Emails will not be sent.
node[287186]: 2025-04-23T09:51:04.796Z [info]: API server is running on http://localhost:3000
node[287186]: 2025-04-23T09:51:04.796Z [info]: Internal server is running on http://localhost:3001
node[287186]: Error: Could not find a production build in the '.next' directory. Try building your app with 'next build' before starting the production server. https://nextjs...
node[287186]: at async createNextServer (../../../nix/store/mqb6z0py0q97v4p1jvr6vwhkx5fw01ij-pangolin-frontend-1.2.0/dist/server.mjs:20576:3)
node[287186]: at async startServers (../../../nix/store/mqb6z0py0q97v4p1jvr6vwhkx5fw01ij-pangolin-frontend-1.2.0/dist/server.mjs:21635:22)
the .next
folder is visible and readable:
tree result/:
dist -> /nix/store/fgmdb49h76bhl5jkw78fhz00wnxci1fv-pangolin-frontend-1.2.0/dist
├── .next -> /nix/store/fgmdb49h76bhl5jkw78fhz00wnxci1fv-pangolin-frontend-1.2.0/.next
├── node_modules -> /nix/store/fgmdb49h76bhl5jkw78fhz00wnxci1fv-pangolin-frontend-1.2.0/node_modules
├── public -> /nix/store/fgmdb49h76bhl5jkw78fhz00wnxci1fv-pangolin-frontend-1.2.0/public
└── standalone -> /nix/store/fgmdb49h76bhl5jkw78fhz00wnxci1fv-pangolin-frontend-1.2.0/standalone
What’s going wrong here? Is there some weird nextjs folder restructuring that I should be doing?
