Hello!
I’m not new to Linux and NixOS but I never faced graphical issues and this part of my system is completely unknown to me.
Before upgrading, I used:
Linux 5.10.52
Nvidia drivers with services.xserver.videoDrivers = [ "nvidia" ];
Because I’m using Steam, I also set up this graphical-related options:
hardware.opengl.extraPackages32 = with pkgs.pkgsi686Linux; [ libva ];
hardware.pulseaudio.support32Bit = true;
After running nixos-rebuild switch --upgrade, Linux kernel version changed to 5.10.62 and nvidia drivers recompiled.
I noticed I couldn’t launch Alacritty (which is OpenGL-based) anymore, so I rebooted, assuming booting on new kernel would solve the issue.
But after boot I was stuck on a black screen. System was behaving normally and the X server seemed to run, as my shortcuts to launch Clementine and play some music worked, but the screen seemed off.
I blindly launched a terminal and captured dmesg output, but I don’t know what to do with it.
I rebooted on the previous system version, but I’m stucked on this version.
Hi @tlater, thanks for the answer.
I use a slightly modified fork of dwm (I replace the dwm package in an overlay) with lightdm.
My dmesg output is here
I can’t find anything interesting there, looking for keywords “error”, “graphic” and “gl”.
Ha! with journalctl ... I found this: (full output here)
Sep 14 13:43:08 sona kernel: nvidia-modeset: ERROR: GPU:0: Display engine push buffer channel allocation failed: 0x65 (Call timed out [NV_ERR_TIMEOUT])
Sep 14 13:43:08 sona kernel: nvidia-modeset: ERROR: GPU:0: Failed to allocate display engine core DMA push buffer
Precision: The screen is turned on at boot time, stage 1 & 2, but stops when the graphics turns on. During shutdown, the screen stays black, and I can’t see systemd’s output.
I guess I should just ban Nvidia ^^
Oh, and my full system configuration is ~1000 LOC… Relevant parts are there:
I have no idea why modesetting is enabled in the first place, if that’s not present in your config. Graphics dropping out after stage 2 makes sense, since by default KMS is enabled after stage 2.
If you’d like to update and can’t resolve the issue, I’d suggest setting a newer or older nvidia package with hardware.nvidia.package, and perhaps checking some nvidia forums and release notes for notes around your GPU.
I know the feeling… Next time I’ll go AMD for sure, or perhaps Intel if they’ve caught their feet by then.
So maybe modesetting is not the issue, but another driver bug (I don’t know anything about drivers though)
I disabled Nvidia drivers, I’ll retry in a few weeks when I’ll have more time.
Thanks for the tips.
