I didn’t. I needed to see the full error to know that it was a missing module arg:
error: infinite recursion encountered
at /nix/store/fpivx4sjcp2vk4rp9nhliln5cwcp3kc6-source/lib/modules.nix:520:28:
519| addErrorContext (context name)
520| (args.${name} or config._module.args.${name})
521| ) (functionArgs f);
and if you look at the line directly before it (in the --show-trace
output), it says
… while evaluating the module argument `inputs' in ":anon-5:anon-1":
which means you didn’t pass inputs
into the module system.
Since you of course passed it into the NixOS config, to me that indicated that the place that was missing was in the HM config, and to pass module args into HM configs, you need to either use _module.args
or home-manager.extraSpecialArgs
(and if the former infrecs then you’d have to use the latter).
Again, why are you creating a separate flake here? A single flake can have multiple outputs.
