Help with nixosModules flake output
I am trying to create a flake (and corresponding git repository) for sharing some common modules between my machines.
It basically just consists of the following:
  description = "Common NixOS configuration for my machines";
    nixpkgs.url = "github:nixos/nixpkgs?ref=nixos-24.05";
  outputs = { self, nixpkgs }: {
    nixosModules = {
      common.imports = [ ./modules/common.nix ];
      desktop.imports = [ ./modules/desktop.nix ];
      server.imports = [ ./modules/server.nix ];
In my server config flake I am trying to use it like this:
  description = "A very basic flake";
    common.url = "git+file:///home/busti/projects/os-common";
  outputs = { self, nixpkgs, common, ... }:
      # individual host configurations
      nixosConfigurations = {
        foo = nixpkgs.lib.nixosSystem {
          system = "x86_64-linux";
          modules = [
            common.nixosModules.server
            ./system/base.nix
However this produces the following error message:
error: getting status of '/nix/store/91dc29jcx81i54av9676dg89d12wfa0p-source/modules': No such file or directory
Am I missing something?
Did you add your files under “modules” to the git repo?
Oof, I put them in the root dir of the flake.
