I’m trying to include noctalia’s templates for various apps while mantaining dynamic colorschemes, for example in kitty i managed to obtain this behaviour by merging a nix-managed config and the noctalia generated one:
config = {
programs.noctalia-shell.settings.templates.activeTemplates = [
id = "kitty";
active = true;
programs.kitty.extraConfig = ''
include themes/noctalia.conf
I’m having problems implementing the same for spicetify (Spotify | Noctalia). I’m using the spicetify flake (GitHub - Gerg-L/spicetify-nix: A nix library for modifying spotify with https://github.com/spicetify) and It seems that it runs in a sandbox and does not access files in the home directory. This is the config i have for the template:
lib,
pkgs,
inputs,
config = {
id = "spicetify";
active = true;
programs.spicetify = let
spicePkgs = inputs.spicetify-nix.legacyPackages.${pkgs.stdenv.system};
theme = {
src = lib.mkForce spicePkgs.themes.comfy;
injectCss = true;
injectThemeJs = true;
replaceColors = true;
overwriteAssets = true;
colorScheme = lib.mkForce "Comfy";
How can I force spicetify into using the file generated by noctalia (in ~/.config/spicetify/Themes/Comfy/colors.ini) without needing to rebuild the entire system when those colors change?
