after nixos-rebuild switch and rebooting it only loads the tty and after a few seconds just displays a blinking cursor and no interactivity. I have to reboot and boot into an earlier generation.
My config mirrors your, other than I am using sddm rather than gdm, so should work. I seem to remember catching this a long time ago - I can’t remember if it was switching from KDE to Gnome, or tinkering with
services.xserver.videoDrivers = [ “nvidia” ];
Do any of those apply? You can leave the above empty and it will go through the default list - that might be worth a try?
Thank you for the tip.
It worked with this line added to the configuration.nix:
# Optionally, you may need to select the appropriate driver version for your specific GPU.
hardware.nvidia.package = config.boot.kernelPackages.nvidiaPackages.legacy_470;
