but I can’t seem to come up with the correct syntax for the home-manager option. I seem that have wandered into brace/bracket/quotation hell. Could someone please let me know how to do this? Greatly appreciated.
Thanks for the quick and detailed reply. I did try exactly what you recommended, but the resulting theme.toml file is not formatted like the default yazi theme.toml, and the changes I am making aren’t producing any results. I am wondering if the home-manager module is not working properly.
It appears to be my mistake. I was trying to change the fg color of the size and percentage pill areas in the status bar, which appears not to be possible. Apparently, it just used the bg of mode_normal as the fg color of these areas. I thought it was because I had not formed my home-manager options correctly.
Do you know of a way to change the fg of these areas to be different from the bg color of mode_normal?
