I want to self-host the nginx image on k3s. I only have one box, so k3s’ role is server
. The documentation describes services.k3s.images
as the best starting place, and helpfully suggests enabling airgapImages
(although the k3s docs leave me confused about what to do with airgap).
After learning about nix-prefetch-docker
and reading the code for pullImage
, I have this, which works! It builds the image in the nix store and links the tarball in /var/lib/rancher/k3s/agent/images/
. So far, so good…
{ config, lib, pkgs, ... }:
imports =
./webapp.nix
services.k3s = {
images = [
(pkgs.dockerTools.pullImage {
imageName = "nginx";
imageDigest = "sha256:d2c11a1e63f200585d8225996fd666436277a54e8c0ba728fa9afff28f075bd7";
sha256 = "0h90vhv9n0is30b95v96jh54f3krfnm5ia6952yq41gwdvf7if69";
finalImageName = "nginx";
finalImageTag = "local";
config.services.k3s.package.airgapImages
Next, I have this manifest. This currently also works. It port-forwards port 80 from the load balancer to localhost, and directs traffic to nginx which returns a 404 as it’s not serving anything. If, however, I change image = "nginx:latest";
to image = "nginx:local";
, the pod errors when pulling the image. From looking at the logs, I can see it’s still trying to pull the image from dockerhub.
services.k3s.manifests.webapp = {
content = [
apiVersion = "v1";
kind = "Pod";
metadata = {
name = "webapp-nginx";
labels = {
"app.kubernetes.io/name" = "webapp";
"app.kubernetes.io/component" = "nginx";
spec = {
containers = [
name = "nginx";
ports = [
containerPort = 80;
name = "http-web-svc";
apiVersion = "v1";
kind = "Service";
metadata = {
name = "webapp-service";
spec = {
selector = {
ports = [
name = "http";
port = 80;
targetPort = "http-web-svc";
I appear to be missing a step between saving images locally (working), and telling k3s to pull the images locally (not working). Can someone offer advice?
