Hi,
The home-manager docs give a starting example which includes hardcoding the system
value. Is it possible to create a flake that works across any system?
I tried using flake-utils
but I suspect I’m misunderstanding something because it’s not working like I expected:
home-manager.url = "github:nix-community/home-manager";
home-manager.inputs.nixpkgs.follows = "nixpkgs";
outputs = { flake-utils, home-manager, nixpkgs, ... }:
username = "test";
pkgs = import nixpkgs {
inherit system;
homeConfigurations.${username} = home-manager.lib.homeManagerConfiguration {
inherit system username pkgs;
configuration = import ./home.nix;
homeDirectory = "/home/${username}";
The error returned:
$ nix build --no-link .#homeConfigurations.test.activationPackage
error: flake 'path:/workspace' does not provide attribute 'packages.aarch64-linux.homeConfigurations.test.activationPackage', 'legacyPackages.aarch64-linux.homeConfigurations.test.activationPackage' or 'homeConfigurations.test.activationPackage'
It helps knowing what that function actually does: flake-utils/default.nix at 12806d31a381e7cd169a6bac35590e7b36dc5fe5 · numtide/flake-utils · GitHub
I.e., it converts homeConfigurations.test.activationPackage
into homeConfigurations.<system>.test.activationPackage
, and repeats that for all default systems. In other words, your command should probably be:
nix build --no-link .#homeConfigurations.x86_64-linux.test.activationPackage
In case you hadn’t realized, nix itself has no support for home-manager, and this flake output should be considered a nonstandard extension. Hence nix build
won’t manage the system setting for you, unlike how it behaves for other flake outputs.
That said, home-manager (the application) has a --flake
switch, which should be preferred over hand invoking things with nix build
. As of roughly a year ago it also did not support specifying the system in the usual flake way either, though, and I don’t think that has changed, so I believe this use case is unsupported.
Personally, I have a little comment with a TODO note in my config telling me to do something about that upstream. I’ve been shy to report it, though, probably because I’m a little annoyed I didn’t catch this when I reviewed the PR that added flake support in the first place
That’s unfortunate it’s not supported. The context I’m working within is container images that are being built for x86 and aarch64 Linux. I was hoping to avoid having to find a way to hack in generating and calling the right config using runtime data in the Dockerfile.
Thanks for explaining the situation, though
No idea if this is feasible for your use case, but if you build those images with nix, you can expose them as derivations in packages
and use flake-utils after all.
Nixpkgs has good support for working with OCI images: NixOS - Nixpkgs 21.11 manual
flake-utils’s eachSystem produce a target hello.aarch64-linux
but home-manager needs packages.aarch64-linux.homeConfigurations
.so just add package:
username = "test";
inherit system;
package = {
then run nix flake show .
you will see:
git+file:///xxx/.config/nixpkgs
└───packages
├───aarch64-darwin
│ └───homeConfigurations omitted (use '--all-systems' to show)
├───aarch64-linux
├───x86_64-darwin
└───x86_64-linux
