homeManagerConfigurations called without required argument 'pkgs'
I’ve added a homeConfigurations for a work machine so that I can have my configurations that I have on my other machines.
desktop builds fine (and I assume the other nixosConfigurations) do as well.
but when I try to build my work homeConfiguration I get this error
This is my flake
Not sure what I am doing wrong as I am believe I am inheriting the right pkgs …
As a best practice on coding forums, please share text rather than screenshots.
Also, based on the title of your post, you just need to pass pkgs as an argument to home-manager.lib.homeManagerConfiguration.
      homeConfigurations.FOOBAR = home-manager.lib.homeManagerConfiguration {
        pkgs = nixpkgs.legacyPackages.x86_64-linux;
and you cannot use useGlobalPkgs or useUserPackages, naturally.
This only applies for standalone HM, of course, not HM as a NixOS module.
Thanks I will use text.
Even adding it as you have here I get
[0] $> home-manager switch --flake github:cookEbox/nix-config#work
error:
   … from call site
     at /nix/store/jwgh7nvqlfbnwqnsr0jmcaswyw02a1ag-source/flake.nix:62:16:
       61|       homeConfigurations = {
       62|         work = home-manager.lib.homeManagerConfiguration {
       63|           inherit pkgs;
   error: function 'homeManagerConfiguration' called with unexpected argument 'home-manager'
   at /nix/store/cd0q2vk9vqwjg9rcilymm4x8f4n673zi-source/flake.nix:41:36:
       40|         hm = (import ./modules/lib/stdlib-extended.nix nixpkgs.lib).hm;
       41|         homeManagerConfiguration = { modules ? [ ], pkgs, lib ? pkgs.lib
       42|           , extraSpecialArgs ? { }, check ? true
Yes, the home-manager options only apply to the NixOS module. For standalone, remove them.
modules = [
./hosts/work/home
Still gets the same error
