I’m converting a few projects to flakes as an excuse to learn them and am a bit puzzled over something. Might be holding it wrong.
I have 3 flaked packages: hag
depends on shellswain
which then depends on comity
When I wire up the overlays the ~naive way, the shellswain
flake builds fine, but then I get eval failures on the hag
flake like:
Function called without required argument "comity" at /nix/store/gpmcl4zrj35m19hxdcvb4a5aa0hk5724-source/shellswain.nix:4
I can:
- fix this at the hag level by fishing the comity overlay out of shellswain’s inputs, but that’s a pretty gross containment breach
re-output the comity overlay at the shellswain level and then use
builtin.attrValues
to pull in all of shellswain’s output overlays, but it’s leaking an implementation detail of one flake into its consumers for incidental reasons - ??? hold it right ???
Both of these options sound like they’d turn into an absolute fragile nightmare in a complex graph of flake-to-flake dependencies–and violate the ~implementation-detail-containment expectations we come to Nix for in the first place.
Am I doing it wrong? Are flakes ~wrong, here?
