I’m playing with mounting a cifs mount, but I run into errors trying to switch.
I have removed my attempt from the configuration file, but I still can’t switch;)
stopping the following units: home-ai-test.mount
restarting systemd...
reloading user units for b0ef...
restarting sysinit-reactivation.target
Error: Failed to get unit home-ai-mnt-proj.mount
Caused by:
Unit home-ai-mnt-proj.mount not loaded.
How can I clean this up?
This is really strange. Can you share the steps you used to reach this point? NixOS shouldn’t be stopping mount units like this. Seems like there’s a bug somewhere.
I really just added this
# fileSystems."/home/ai/test" = {
# device = "//10.100.0.1/proj";
# fsType = "cifs";
# options = let
# # network split
# automount_opts = "x-systemd.automount,noauto,x-systemd.idle-timeout=60,x-systemd.device-timeout=5s,x-systemd.mount-timeout=5s,user,users";
# #automount_opts = "x-systemd.automount,noauto,x-systemd.idle-timeout=60,x-systemd.device-timeout=5s,x-systemd.mount-timeout=5s";
# #in ["${automount_opts},credentials=/etc/smb-secrets-quasar"];
# in ["${automount_opts},credentials=/etc/smb-secrets-quasar,uid=1005,gid=100"];
I did have the target as /home/ai/mnt/proj or something like that before I tried /home/ai/test
Hm, I think there’s probably some bugs with switch-to-configuration
and x-systemd.automount
I have to reboot to last configuration? I can’t clean this up without going that route?
I think I may have run into a different version of what you’re seeing.
I was doing frequent tweaks trying to get an automount working and was getting really weird symptoms.
The weird symptoms went away when I started this process when I needed to make a change
- comment out mount config
- nixos-rebuild --switch
- Reboot
- Uncomment mount and make changes
I can’t say if what I was running into was unique to mount units though cause all the systemd services I setup that weren’t mounts worked on my first try.
P.S. : I’m already in triple digit generation after less than 2 weeks because I had to do this so much lol
I did a reboot and all is well now, but kinda wanna figure out what happened here;)
Like I said, I think we have undiagnosed bugs in switch-to-configuration
w.r.t. x-systemd.automount
. I think we need someone to do some work to test and experiment with switch-to-configuration
to see what it’s doing wrong.
