How to add a NUR package to a flake
Hello, I would appreciate advice on how to add a NUR package (pyrosm-from-nur in the example below) to the flake:
  description = "Flake with NUR package";
    nixpkgs.url = "nixpkgs/nixos-21.11";
    nur.url = github:nix-community/NUR;
  outputs = { self, nixpkgs, flake-utils, nur }:
        proj-name = "baz";
        method-one-name = "method-one-${proj-name}";
        method-one-buildInputs = with pkgs; [ cowsay coreutils ];
        # method-one-buildInputs = with pkgs; [ cowsay coreutils pyrosm-from-nur ];
        method-one-script = (pkgs.writeScriptBin method-one-name ''
        #!/usr/bin/env bash
        cowsay "one!"
        '').overrideAttrs(old: {
          buildCommand = "${old.buildCommand}\n patchShebangs $out";
      in rec {
        defaultPackage = packages.${proj-name};
        packages.${proj-name} = pkgs.symlinkJoin {
          name = "${proj-name}";
          paths = [ method-one-script ] ;
          buildInputs = [ pkgs.makeWrapper ];
          postBuild = ''
            wrapProgram $out/bin/${method-one-name} --prefix PATH : ${pkgs.lib.makeBinPath method-one-buildInputs}
        apps.method-one  = {
          type = "app";
          program = "${packages.${proj-name}}/bin/${method-one-name}";
        devShell =  pkgs.mkShell {
          buildInputs = [ self.packages.${system}.${proj-name} ]
          ++ method-one-buildInputs;
Try with
nix develop
 method-one-baz
 ______
< one! >
        \   ^__^
         \  (oo)\_______
            (__)\       )\/\
                ||----w |
Many thanks.
