Hello, I am trying to use home-manager module to config my neovim and I am using nixos-unstable channel. But when I add nvim-treesitter plugin, I got an error.
Here is the error.
❮ home-manager switch
error:
at <nix/derivation-internal.nix>:37:12:
36|
37| strict = derivationStrict drvAttrs;
38|
… while evaluating derivation 'home-manager-generation'
whose name attribute is located at /nix/store/4cbg4rsanwlrgpgrw1926lxhy1723k70-source/pkgs/stdenv/generic/make-derivation.nix:536:13
… while evaluating attribute 'buildCommand' of derivation 'home-manager-generation'
at /nix/store/4cbg4rsanwlrgpgrw1926lxhy1723k70-source/pkgs/build-support/trivial-builders/default.nix:80:17:
79| enableParallelBuilding = true;
80| inherit buildCommand name;
81| passAsFile = [ "buildCommand" ] ++ (derivationArgs.passAsFile or [ ]);
… while evaluating the option `home.file."/home/luke/.local/share/nvim/site/pack/hm".source':
… while evaluating definitions from `/nix/store/95ri06chrqlrdkk48g8krhyky5ymv7xz-source/modules/misc/xdg.nix':
… while evaluating the option `xdg.dataFile."nvim/site/pack/hm".source':
… while evaluating definitions from `/nix/store/95ri06chrqlrdkk48g8krhyky5ymv7xz-source/modules/programs/neovim.nix':
error: You cannot include two different versions of nvim-treesitter, perhaps you included a legacy plugin together with a new one?
Here is my configuration.
neovim = {
viAlias = true;
vimAlias = true;
defaultEditor = true;
initLua = lib.fileContents ./init.lua;
plugins = with pkgs.vimPlugins; [
nvim-treesitter
better-escape-nvim
yazi-nvim
todo-comments-nvim
rainbow-delimiters-nvim
luasnip
blink-cmp
telescope-nvim
nvim-autopairs
friendly-snippets
nvim-lspconfig
mason-nvim
gitsigns-nvim
conform-nvim
which-key-nvim
nvim-tree-lua
indent-blankline-nvim
nvim-web-devicons
nvzone-minty
nvzone-menu
nvzone-volt
nvchad-ui
base46
plenary-nvim
nvchad
lazy-nvim
As you can see, I only added the nvim-treesitter plugin once.
Thanks for replies.
