Hi,
I have been working on building a cross-compiler using Clang and LLVM, designed to compile RISC-V executables on an x86 host machine.
When building it manually, I could build the Clang+LLVM cross-compiler first and use the cross-compiler to build the RISC-V runtime libraries and install it alongside LLVM so that Clang could find them.
When building it with Nix, I defined 3 separate derivations for Clang+LLVM, compiler-rt, and newlib and used symlinkJoin
to put them into the same directory structure. However, despite being placed together, Clang failed to find the runtime libraries since the search path was configured during the configurePhase
using CMake, which only included the output path of the Clang+LLVM derivation.
$ ls /nix/store/wd5...lqq-clang # clang only searches this path for runtime libraries
bin include lib libexec share
$ ls /nix/store/07m...lwv-compiler-rt # compiled with clang
include lib
$ ls /nix/store/92i...51g-newlib # also compiled with clang
riscv64-unknown-elf share
$ ls `readlink result` # the result of symlinkJoin, but clang won't know runtime libraries are here.
bin include lib libexec riscv64-unknown-elf share
Is it possible to install the runtime libraries directly into Clang’s output path? Alternatively, could I install Clang at the location where the runtime libraries are intended to be placed? Or perhaps there’s a better approach to achieve this that I should consider?
Any help or suggestion would be appreciated!
