To slowly migrate my dotfiles into home-manager, I would like to have the option to inspect and copy legacy dotfiles into a non-nix/os system.
I would like to have a single home.nix
in my flake source tree that gets used in a output.nixosSystem
and also in a output.homeManagerConfigurations
Is there a way to define a single home-manager module for both output targets?
Or, alternatively, can I somehow home-manager build
just the home directory from a nixosSystem
target?
To reproduce the attempt, a minimal flake.nix
and home.nix
flake.nix:
description = "multi target, single home-manager config";
nixpkgs.url = "github:nixos/nixpkgs?ref=nixos-unstable";
home-manager = {
outputs = { self, nixpkgs, home-manager }:
nixosConfigurations.OS = nixpkgs.lib.nixosSystem {
system = "x86_64-linux";
specialArgs = { inherit home-manager; };
modules = [
boot.isContainer = true;
users.users.USER = { isNormalUser = true; };
./home.nix
homeConfigurations.HOME = home-manager.lib.homeManagerConfiguration {
pkgs = nixpkgs.outputs.legacyPackages.x86_64-linux;
extraSpecialArgs = { inherit home-manager; };
modules = [ ./home.nix ];
home.nix:
{ home-manager, ... }:
imports = [ home-manager.nixosModules.home-manager ];
home-manager.users.USER.home = {
stateVersion = "24.11";
Building the nixos system with nixos-rebuild --flake .#OS
works fine but home-manager build --flake .#HOME
fails, in this example case with error: The option 'home.stateVersion' is used but not defined.
. Other tries failed with infinite recursion or even cache errors.
