I am trying to build leftwm-theme, and I start off with a derivation like this:
{ config, pkgs, lib, rustPlatform, fetchFromGitHub, ... }:
rustPlatform.buildRustPackage rec {
pname = "leftwm-theme";
version = "e6907a663ec56397ccbe4f1226ac0550ec6678f0";
src = fetchFromGitHub {
owner = "leftwm";
repo = pname;
rev = version;
sha256 = "12x6a487qzsngr99z39902v7c7f4xkwjximmn3wmzdz8bjddw2d2";
cargoSha256 = "0g6xp1dn56dfscybvrm1wmq75zi8n2lxcv81xs969a705dj5s1ml";
meta = with lib; {
description = "A tool to help manage themes for LeftWM";
homepage = "https://github.com/leftwm/leftwm-theme";
license = licenses.bsd3;
maintainers = [];
Then I got the following error:
Executing cargoBuildHook
++ env CC_x86_64-unknown-linux-gnu=/nix/store/74kv08wjf06ifgk4dxrnra4qhzr5s1w4-gcc-wrapper-10.3.0/bin/cc CXX_x86_64-unknown-linux-gnu=/nix/store/74kv08wjf06ifgk4dxrnra4qhzr5s1w4-gcc-wrapper-10.3.0/bin/c++ CC_x86_64-unknown-linux-gnu=/nix/store/74kv08wjf06ifgk4dxrnra4qhzr5s1w4-gcc-wrapper-10.3.0/bin/cc CXX_x86_64-unknown-linux-gnu=/nix/store/74kv08wjf06ifgk4dxrnra4qhzr5s1w4-gcc-wrapper-10.3.0/bin/c++ cargo build -j 4 --target x86_64-unknown-linux-gnu --frozen --release
error: the lock file /build/source/Cargo.lock needs to be updated but --frozen was passed to prevent this
If you want to try to generate the lock file without accessing the network, use the --offline flag.
Then I checked the doc, it mentions that I can use a patch for Cargo.lock
As patch is a file to show the difference between the old and the updated file, I decided to folk and update the lock file in my own repo and use it to build the package for testing. However, I am still getting the exact same result. Why is that?
