I would like to deploy say 100 VMs on Virtualbox using NixOps.
The load-balancer.nix example shows how to deploy 2 exact same machines, but how can i deploy n effectively?
I could write this, but that would not be very effectively:
backend1 = backend;
backend2 = backend;
backendn = backend;
I haven’t ever done anything this before, but presumably you could write something like
# all other attrs
} // lib.attrsets.genAttrs (map (i: "backend${toString i}") (lib.lists.range 1 100)) (_: backend)
Edit: Alternative syntax if you care for it:
# all other attrs
} // builtins.foldl' (a: b: a // b) {} (map (i: { "backend${toString i}" = backend; }) (lib.lists.range 1 100))
Thanks.
I got this error that lib
is not defined
error: undefined variable 'lib' at /home/davidak/code/nixops-targets/load-balancer.nix:36:6
error: evaluation of the deployment specification failed
but found the solution in the manual:
https://nixos.org/nixops/manual/#examples-18
with import <nixpkgs/lib>;
(The example in the manual is outdated btw)
