In Software packaging and distribution for LHCb using Nix, the authors write:
In order to facilitate this use, software must be stable for long
periods; much longer than even Long Term Support operating systems are
available. Additionally, the software should reproduce any and all
bugs which were present in the original version to ensure the accuracy
of the final results. Builds should be reproducible to allow for
patches to be carefully introduced.
But NixOS configuration files do not include versions of packages (unlike, say, Rust manifests), e.g.
git
git-lfs
fish
neovim
nixpkgs-fmt
nixos-option
# Basic utils
killall
If I understand correctly, packages can be updated within a channel, and they can change when the channel is changed.
Then, how to ensure that in 10 years I will be able to get or build the same Nix environment with the same versions packages installed?
