I’m trying to use buildNpmPackage
which requires an npmDepsHash
. Now I’m using this a separate repository to do this so it’s not part of nixpkgs.
Previously when I used node2nix, I could put it into an IFD, so I can just run it.
However now it appears prefetch-npm-deps
is impure, and I cannot put it into an IFD.
I want a derivation I can just run directly like nix-build ./release.nix -A application
that doesn’t require me to precalculate the prefetch-npm-deps
prior. It should just figure it out directly from the ./package-lock.json
Is there a way to do this?
