I’m using the nixos-rebuild build-vm
command to create virtual machines based on nixosSystem
s. It works great and I’m able to edit everything in a single file, issue a single command and a fully configured system appears. This approach, while good for a single VM, lacks a good interface to manage multiple machines and relies too much on the terminal.
Recently, I started messing with virt-manager
and would like to, instead of building a single machine with build-vm
, build multiple and manage them through virt-manager
, where I could start machines in the background, stop, delete and easily configure them after they are initially generated. I don’t want to create an ISO, install and configure each VM.
I know that the build-vm
command spits out a result/bin/run-nixos-vm
which contains a qemu-kmv
command with all the necessary parameters, but I’m not very skilled with VMs so I don’t know how to use or change the virtualisation.*
configs to easily use the fully configured VM in virt-manager
Does anyone have a specific ergonomic approach for this?
I’m not familiar with qemu, but hopefully this helps you get started: config.system.build.vm
(or if you want a bootloader, config.system.build.vmWithBootloader
) will contain the realised config in vm form.
Thank you for the help though I think this is not exactly what I needed. I searched a bit more and found a similar question to mine which had a very useful reply. NixVirt appears to be the optimal solution when you need to manually write XML configurations. While this approach works well, I need to read a bit more to see if configurations can be defined externally to my system flake configuration. i.e: when using build-vm
, I want to use a separate flake file to define an entirely new NixOS VM system.
I also found information on the nixos-build-vms command, which can create several vms and connect them with just one declaration [1, 2]. This command is nice but still is not managed by a interface such as virt-manager
Since the parameters of the result of build-vm
are declared here, one could create a nix derivation to mimic this shell but generating a XML for virsh
, but that’s a whole new challenge.
In the meantime, I think I’ll use the nixos-build-vms
command for easily creating a network of VMs until I find a better approach with virt-manager
and maybe NixVirt
. If find one, I’ll comeback here.
