How to make buildNpmPackage read two package-lock.json
I am trying to create a package for a nodejs app defined at AceMagic-S1-LED-TFT-Linux/s1panel at main · tjaworski/AceMagic-S1-LED-TFT-Linux · GitHub (All relevant code is in s1panel directory).
The first issue I found with the app(s) is regarding package-lock.json file(s) are not present in the repo, so in the end I decided to fork it and add them with other minor configuration files. After that, I was able to create a nix package but, the code is split in two coupled nodejs folders/apps: main and api/gui. If you have a look at the install script you can see first is performing npm install in s1panel then npm install in s1panel/gui and finally build the gui app npm run build, later the service is launched by running the main.js file in s1panel folder.
I would like to know if there is a way to use buildNpmPackage in this scenario, picking up dependencies from two sources, doing build on the second one.
This is what I have been trying:
  lib,
  buildNpmPackage,
  # importNpmLock,
  fetchNpmDeps,
  npmHooks,
  pkgs,
  pkg-config,
  nodejs_22,
  makeWrapper,
  lm_sensors,
  pixman,
  cairo,
  pango,
  libudev-zero,
  pname = "s1panel";
  version = "2024-04-09";
  src = pkgs.fetchgit {
    url = "https://github.com/jriguera/AceMagic-S1-LED-TFT.git";
    sparseCheckout = [
      "s1panel"
    rev = "refs/tags/0.1.0";
    hash = "sha256-QyO/8CXwYclDdMEJJj5qHQsMbnqYfWGXcvWLBsdQvA0=";
  npmDepsMain = fetchNpmDeps {
    name = "npm-deps-main";
    src = "${src}/s1panel";
    hash = "sha256-lD5AVFE5fPPZ9FV6DSUNE0w+bnoDoqttbV86Cp7FpuA=";
  npmDepsGui = fetchNpmDeps {
    name = "npm-deps-gui";
    src = "${src}/s1panel/gui";
    hash = "sha256-Jc16eK59dNqX85SpBH8htIiwX5pG9bwJqZDpznW/eNQ=";
  buildNpmPackage {
    inherit pname version;
    # This hash is generated at build time, and uniquely identifies
    # the cache of NodeJS dependencies used for the build.
    # npmDepsHash = lib.fakeHash;
    #npmDepsHash = "sha256-lD5AVFE5fPPZ9FV6DSUNE0w+bnoDoqttbV86Cp7FpuA=";
    buildInputs = [
       pixman
       cairo
       pango
       libudev-zero
     nativeBuildInputs = [
       pkg-config
       makeWrapper
     nodejs = pkgs.nodejs_22;
     postPatch = ''
       echo Here
       npm
       # Tricky way to run npmConfigHook multiple times
         local postPatchHooks=() # written to by npmConfigHook
         source ${npmHooks.npmConfigHook}/nix-support/setup-hook
         npmRoot=.     npmDeps=${npmDepsMain}     npmConfigHook
         npmRoot=./gui npmDeps=${npmDepsGui}      npmConfigHook
       echo "Done"
     installPhase = ''
       runHook preInstall
       mkdir -p $out
       cp -r * $out
       runHook postInstall
     # needs to be wrapped with nodejs so that it can be executed
     postInstall = ''
      chmod +x $out/main.js
      makeWrapper $out/main.js $out/bin/s1panel --prefix PATH:"${lib.makeBinPath [nodejs_22]}"
    meta = with lib; {
      description = "S1 Panel";
      homepage = "https://github.com/tjaworski/AceMagic-S1-LED-TFT-Linux";
      license = licenses.gpl3Only;
      maintainers = with maintainers; [];
      platforms = platforms.linux;
      mainProgram = "s1panel";
I took some inspiration from this post Need help with buildNpmPackage and pagefind derivation but I am getting npm: command not found:
warning: found empty hash, assuming 'sha256-AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA='
these 2 derivations will be built:
  /nix/store/vvcghkzq8fkhw1lhl22kf9963fzjalwl-s1panel-2024-04-09-npm-deps.drv
  /nix/store/k8099k8s8qg95vz8bbg286ngr248z1fs-s1panel-2024-04-09.drv
building '/nix/store/vvcghkzq8fkhw1lhl22kf9963fzjalwl-s1panel-2024-04-09-npm-deps.drv'...
Running phase: unpackPhase
unpacking source archive /nix/store/v4b86bxzzj97mj5v3lfmkw5yci6lhyl3-AceMagic-S1-LED-TFT/s1panel
source root is s1panel
Running phase: patchPhase
Here
/nix/store/rnph566f9n93lnda6wrlcip5wpxmlmlb-stdenv-linux/setup: line 228: npm: command not found
note: keeping build directory '/tmp/nix-build-s1panel-2024-04-09-npm-deps.drv-54/build'
error: builder for '/nix/store/vvcghkzq8fkhw1lhl22kf9963fzjalwl-s1panel-2024-04-09-npm-deps.drv' failed with exit code 127;
       last 6 log lines:
       > Here
       For full logs, run 'nix-store -l /nix/store/vvcghkzq8fkhw1lhl22kf9963fzjalwl-s1panel-2024-04-09-npm-deps.drv'.
error: 1 dependencies of derivation '/nix/store/k8099k8s8qg95vz8bbg286ngr248z1fs-s1panel-2024-04-09.drv' failed to build
