How to mount network shares to use as data storage
I would like to use the following service options and store my data on my unraid file storage. It is mainly about mysql and nextcloud:
services.mysql.dataDir
services.nextcloud.home
Unfortunately I get authorization errors no matter if I mount with nfs or smb. How do I have to mount a network share so that the two options for mysql and nextcloud work?
This is the nfs mount for example
fileSystems."/mnt/Daten" = {
    device = "192.168.1.3:/mnt/user/Daten";
    fsType = "nfs4";
    options = [ "rsize=32768,wsize=32768,noatime,async" ];
this is the bind mount:
fileSystems."/var/lib/mysql" = {
  depends = [
      # The mounts above have to be mounted in this given order
      "/mnt/Daten/Mysql"
      "/var/lib/mysql"
  device = "/mnt/Daten/Mysql";
  fsType = "none";
  options = [
    "bind"
This are the permissions:
drwxrwxrwx  1 specter       users           28 18. Jun 11:20 mysql
This is the error:
 mysql.service: Failed to set up special execution directory in /var/lib: Operation not permitted
