Let’s say I have a derivation in flake.nix, with only nixpkgs as input.
I want to download/prefetch every build dependencies of that derivation from cache.nixos.org to local /nix/store, so that when I run
nix buid --offline github:myname/myrepo#mypackage
it will not build anything from nixpkgs.
Is there any method/command to achieve this?
EDIT: Assume there is no IFD
For NixOS there’s the system.includeBuildDependencies option. I’ve never looked into the implementation, but I bet you could try to reuse the code or at least the same approach for a general derivation.
EDIT: Indeed, it’s based on pkgs.closureInfo, which can be used on any derivation.
Do you want deep dependencies too or just an offline build? I would just run it with -j0 for the latter; for the former you need to instantiate the derivation to build, ask for its closure, then realise each derivation in the closure with -j0
