Let’s say a derivation provides some script via passthru:
passthru.script1 = ./script1.sh;
How can I run this script with nix-shell?
That will depend on what you are trying to achieve.
For many use cases, the script will be self-contained, so you could just obtain a path to it and execute it directly, without
nix-shell
.How exactly you will do that depends on how is the script defined.
If it is a just a path like in your example, or in cacert, you can instantiate the attribute path to get absolute path to run:
$ nix-instantiate --eval -A cacert.updateScript /home/jtojnar/Projects/nixpkgs/pkgs/data/misc/cacert/update.sh
If it is a derivation, like in gonic, you will want to build it first.
$ nix-build -A gonic.updateScript /nix/store/y7rk79v3smxbpz4r3i5nkg5aicl9wy3y-update-gonic
If there are some dependencies, you could run the updated path using
nix-shell -p foo -p bar --run "$(nix-instantiate --eval -A cacert.updateScript)"
Though
updateScript
s specifically have their own launcher so you would usenix-shell maintainers/scripts/update.nix --argstr path cacert
rather than executing them directly. -
If the script is supposed to modify the environment for the
nix-shell
, you would have tosource
it.- Directly in bash using something like
nix-shell -p curl --run 'bash --init-file <(echo ". \\"$HOME/.bashrc\\"; . \\"$(nix-instantiate --eval -A mypackage.script1)\\"")'
(apparently, bash does not offer a nice way to do this) - Writing a custom expression for a shell and sourcing the script in
shellHook
. That is create the followingfoo.nix
file and runnix-shell foo.nix
:let pkgs = import <nixpkgs> { }; in pkgs.mkShell { buildInputs = [ pkgs.curl ]; shellHook = '' . ${pkgs.mypackage.script1} ''; }
