How to set the value of $0 inside wrapped script when using makeWrapper/wrapProgram?
I’m trying to wrap an executable with makeWrapper or wrapProgram like:
wrapProgram $out/bin/the-exe <some_more_args>
My problem is that the program the-exe acts differently depending on the value of $0: there are different symlinks pointing to it, and depending on the symlink that is called, the value of $0 inside the-exe is equal to the symlink name… But when i use wrapProgram this way, the value of $0 is always $out/bin/.the-exe-wrapped, no matter what symlink I use to call the-exe. Is there a way to change the value of $0 as seen inside the-exe?
I know that makeWrapper has the option --argv0, but when I do
echo $0
inside the-exe, the value is always “$out/bin/.the-exe-wrapped” and not the value I passed to --argv0.
This is unfortunately a limitation of Linux. It discards passed argv[0] when executing a script with shebang – it will only apply to ELF programs.
Cannot find any reference to the behaviour other than https://unix.stackexchange.com/a/562634/41260https://unix.stackexchange.com/a/562634/41260 at the moment.
In case of Python we use NIX_PYTHONEXECUTABLE and set sys.argv[0] to it in a sitecustomize.py.
Maybe you can move the binaries and symlinks into another directory without changing the names, and use makeWrapper to create wrappers in /bin
