I have NixOS 22.11 set up on a local workstation.
I use extra-container package, which can run declarative NixOS containers like imperative containers, without system rebuilds.
I’m trying to run a demo container. It downloads and uzips woocommerce
inside container and i want to synchronize these files between the container and my local system path. The main purpose is to learn nix better. In a docker-compose I can could have used config like this:
volumes:
- <local-path>:<container-path>
How can I achieve it in a NixOS container that does not use docker?
I tried these configs, but my local system directory remains empty:
fileSystems."/var/www/demo/wp-content/plugins/woocommerce" = {
device = "/root/woocommerce";
options = [ "bind" ];
# noCheck = true;
serviceConfig = {
BindPaths = [ "/var/www/demo/wp-content/plugins/woocommerce:/root/woocommerce" ]
full config of woo.nix
{ pkgs, ... }:
containers.demo = {
config = {
# noCheck = true;
users.users.demo = {
isSystemUser = true;
createHome = true;
group = "demo";
users.groups.demo = { };
systemd.services.woo = {
path = with pkgs; [ coreutils wget gzip curl unzip ];
script = ''
/run/current-system/sw/bin/curl -L https://downloads.wordpress.org/plugin/woocommerce.7.4.1.zip -o /root/woocommerce.zip &&
unzip /root/woocommerce.zip -d /root &&
rm /root/woocommerce.zip
serviceConfig = {
BindPaths = [ "/var/www/demo/wp-content/plugins/woocommerce:/root/woocommerce" ];
# ReadWriteDirectories = [ "/root/woocommerce" ];
environment.systemPackages = [ pkgs.coreutils pkgs.wget pkgs.gzip pkgs.curl pkgs.unzip ];
I run it with the command:
sudo extra-container create --start <<EOF
$(cat woo.nix)
EOF
What is the best way synchronize files between a NixOS declarative container and a local system?
