Erwyn
1
Hello,
I would like to test a PR by integrating it into my system flake. Namely, I want to test nixos/writefreely: add support for email smtp password + minor fixes by jbgi · Pull Request #458481 · NixOS/nixpkgs · GitHub which make changes in the writefreely NixOS module. I would like to incorporate it into my flake in a way that only swaps this module from my flake, not the rest.
Is there a way to achieve that ?
Add the PR branch as a flake input, then add the module toimports. You’ll also need to disable the existing module (if it’s an existing module):
{ modulesPath, inputs, ... }:
imports = [ "${inputs.nixpkgs-pr}/nixos/modules/.../whatever.nix"` ];
disabledModules = [ "${modulesPath}/.../whatever.nix" ]; # note that "/nixos/modules" isn't added on here
Erwyn
3
Thanks for the help, I will try that.
