I broke my store need help
I made something in my /nix/store I don’t remember .
making impossible to install software:
$ nix profile install nixpkgs#pastebinit
error: filesystem error: directory iterator cannot open directory: No such file or directory [/nix/store/cxa7l1hawbdkal340m38mfbmn54ssv4i-pastebinit-1.6.2]
[ble: exit 1]
# here with debug
'/nix/var/nix' does not exist, so Nix will use '/data/avargas/nixsa/share/root' as a chroot store
evaluating file '<nix/derivation-internal.nix>'
evaluating derivation 'flake:nixpkgs#pastebinit'...
using cache entry 'file:{"name":"flake-registry.json","store":"/nix/store","url":"https://channels.nixos.org/flake-registry.json"}' -> '{"etag":"W/\"000191f1e8b067fb44be0f6e2f655c952721a897d4e8c9b38207be8864cc3b51\"","storePath":"5bs7lbd1fk22w7bzdd8d6fvysnyzgw35-flake-registry.json","url":"https://channels.nixos.org/flake-registry.json"}'
acquiring write lock on '/data/avargas/nixsa/share/root/nix/var/nix/temproots/3161418'
using cache entry 'file:{"name":"flake-registry.json","store":"/nix/store","url":"https://channels.nixos.org/flake-registry.json"}' -> '{"etag":"W/\"000191f1e8b067fb44be0f6e2f655c952721a897d4e8c9b38207be8864cc3b51\"","url":"https://channels.nixos.org/flake-registry.json"}', '/nix/store/5bs7lbd1fk22w7bzdd8d6fvysnyzgw35-flake-registry.json'
looked up 'flake:nixpkgs' -> 'github:NixOS/nixpkgs/nixpkgs-unstable'
using cache entry 'file:{"name":"source","store":"/nix/store","url":"https://api.github.com/repos/NixOS/nixpkgs/commits/nixpkgs-unstable"}' -> '{"etag":"W/\"1cbb128d3a8e17855c17b67a1401e07d59ebe32695a54e294a04760786ba33cb\"","storePath":"1xr851cf3s01nw0jk5k2m0zlpk9gicvc-source","url":"https://api.github.com/repos/NixOS/nixpkgs/commits/nixpkgs-unstable"}'
using cache entry 'file:{"name":"source","store":"/nix/store","url":"https://api.github.com/repos/NixOS/nixpkgs/commits/nixpkgs-unstable"}' -> '{"etag":"W/\"1cbb128d3a8e17855c17b67a1401e07d59ebe32695a54e294a04760786ba33cb\"","url":"https://api.github.com/repos/NixOS/nixpkgs/commits/nixpkgs-unstable"}', '/nix/store/1xr851cf3s01nw0jk5k2m0zlpk9gicvc-source'
HEAD revision for 'github:NixOS/nixpkgs/nixpkgs-unstable' is 5083ec887760adfe12af64830a66807423a859a7
using cache entry 'gitRevToTreeHash:{"rev":"5083ec887760adfe12af64830a66807423a859a7"}' -> '{"treeHash":"f39d957bb09f9f3bef86cd12bf7f1cf7a6403984"}'
using cache entry 'gitRevToLastModified:{"rev":"5083ec887760adfe12af64830a66807423a859a7"}' -> '{"lastModified":1731890469}'
using cache entry 'fetchToStore:{"fingerprint":"5083ec887760adfe12af64830a66807423a859a7","method":"nar","name":"source","path":"/","store":"/nix/store"}' -> '{"storePath":"n1g84klfb0h3bpwyvc59lcy5ca58h36w-source"}'
using cache entry 'fetchToStore:{"fingerprint":"5083ec887760adfe12af64830a66807423a859a7","method":"nar","name":"source","path":"/","store":"/nix/store"}' -> 'null', '/nix/store/n1g84klfb0h3bpwyvc59lcy5ca58h36w-source'
store path cache hit for '«github:NixOS/nixpkgs/5083ec887760adfe12af64830a66807423a859a7»/'
got tree '/nix/store/n1g84klfb0h3bpwyvc59lcy5ca58h36w-source' from 'github:NixOS/nixpkgs/5083ec887760adfe12af64830a66807423a859a7?narHash=sha256-D1FNZ70NmQEwNxpSSdTXCSklBH1z2isPR84J6DQrJGs%3D'
evaluating file '/data/avargas/nixsa/share/root/nix/store/n1g84klfb0h3bpwyvc59lcy5ca58h36w-source/flake.nix'
old lock file: {
  "nodes": {
    "root": {}
  "root": "root",
  "version": 7
computing lock file node ''
new lock file: {
  "nodes": {
    "root": {}
  "root": "root",
  "version": 7
trying flake output attribute 'packages.x86_64-linux.pastebinit'
using cached attrset attribute ''
trying flake output attribute 'legacyPackages.x86_64-linux.pastebinit'
trying flake output attribute 'pastebinit'
using cached string attribute 'legacyPackages.x86_64-linux.pastebinit.type'
using cached string attribute 'legacyPackages.x86_64-linux.pastebinit.drvPath'
using cached list of strings attribute 'legacyPackages.x86_64-linux.pastebinit.meta.outputsToInstall'
querying info about missing paths...
starting pool of 24 threads
building of '/nix/store/lqzivzdqayrlhymf2aijs6pzb74manwg-pastebinit-1.6.2.drv^out' from .drv file: created
building of '/nix/store/lqzivzdqayrlhymf2aijs6pzb74manwg-pastebinit-1.6.2.drv^out' from .drv file: woken up
entered goal loop
building of '/nix/store/lqzivzdqayrlhymf2aijs6pzb74manwg-pastebinit-1.6.2.drv^out' from .drv file: return_value(Co&&)
building of '/nix/store/lqzivzdqayrlhymf2aijs6pzb74manwg-pastebinit-1.6.2.drv^out' from .drv file: in final_awaiter
building of '/nix/store/lqzivzdqayrlhymf2aijs6pzb74manwg-pastebinit-1.6.2.drv^out' from .drv file: init
building of '/nix/store/lqzivzdqayrlhymf2aijs6pzb74manwg-pastebinit-1.6.2.drv^out' from .drv file: loading derivation
building of '/nix/store/lqzivzdqayrlhymf2aijs6pzb74manwg-pastebinit-1.6.2.drv^out' from .drv file: have derivation
building of '/nix/store/lqzivzdqayrlhymf2aijs6pzb74manwg-pastebinit-1.6.2.drv^out' from .drv file: done
building of '/nix/store/lqzivzdqayrlhymf2aijs6pzb74manwg-pastebinit-1.6.2.drv^out' from .drv file: goal destroyed
It looks like you broke your fs. If I read the output you pasted correctly your store is at /data/avargas/nixsa/share/root. Does find /data/avargas/nixsa/share/root/ -exec true \; also fail? If so your problem is not nix-specific. Maybe you can unmount the fs of your store and run fsck on it.
thanks I restarted again from scratch …
