I feel like NIX_PATH creates more issues than it fixes
Two issues from my point of view:
  1. NIX_PATH gets cached since applications do not re-source /etc/set-environment due to this if statement located in /etc/profile
if [ -z "$__NIXOS_SET_ENVIRONMENT_DONE" ]; then
    . /nix/store/sm7s4dlgji6p2gzigh5xalxwly372ijg-set-environment
fi
  1. PAM environment depends on NIX_PATH (I am not sure why :/) which means that it gets rebuilt each time NIX_PATH changes, and in my case it happens on each rebuild:
❯ echo $NIX_PATH | sed 's/:/\n/g'
/home/gytis/.nix-defexpr/channels
repl=/nix/store/6qrsfdyd64jgkycbnm032cd8x7szch8a-source/repl.nix
home-manager=/nix/store/bmf3jwgp67ixy8imw41rl68kmnhc1r4p-source
neovim=/nix/store/mln4f4jkczv5jzx7pmxp6pv8vl297abg-source
nixpkgs=/nix/store/mz372xs1z8r6b3337zs0qxkg0ffrbnn3-source
nixpkgs-wayland=/nix/store/pgkpb8015dwxi7xzfjazjdh74y79i14x-source
nur=/nix/store/yipghf9hym51wy5a6fcnxap4bbb0id0b-source
self=/nix/store/6qrsfdyd64jgkycbnm032cd8x7szch8a-source
utils=/nix/store/n8hd2prmkxb8f584faqycd01czvb83ck-source
Admittedly, I am planning on changing the implementation of the use cases I am handling here, so I guess it’s not much of an issue.
An alternative implementation of NIX_PATH:
If possible - should get directly passed to applications that require it via config.nix.nixPath - otherwise file is read when required from /etc/nix which contains its definition (similar to the registry)
Could it be that I am missing some use cases?
Based on what you describe here you are probably better off using flakes already.
I am using flakes, but as I said - I will change my flakes implementation at least partially. But then again, it’s not like flakes deprecate NIX_PATH
Edit: now that I think about it, in the case when using flakes (nixUnstable) - the only use case is when using nix repl (assuming you don’t have any automagic script for it). Cant think of any other “legit” cases
Better use something like this:
  environment.etc."channels/nixpkgs".source = nixpkgs.outPath;
  environment.etc."channels/home-manager".source = home-manager.outPath;
  nixPath = [
    "nixpkgs=/etc/channels/nixpkgs"
    "home-manager=/etc/channels/home-manager"
where nixpkgs and home-manager are flake inputs.
The entries in /etc will be relinked during activation and your applications will be able to see the updated channels.
I don’t think that /etc is the correct place to place em but yeah, I was thinking about something similar.
I created this post, not in search of a workaround, but to create a discussion if we actually can consider getting rid of the NIX_PATH environment variable. I feel like this would be a quite an appropriate addition to Nix 3.0
An empty NIX_PATH works also with nix repl. Just use builtins.getFlake instead of :l or import.
$ NIX_PATH= nix repl
Welcome to Nix version 2.4pre20210308_1c0e3e4. Type :? for help.
nix-repl> :l <nixpkgs>
error: file 'nixpkgs' was not found in the Nix search path (add it using $NIX_PATH or -I)
nix-repl> flake = builtins.getFlake "/etc/nixos"
nix-repl> flake.inputs.nixpkgs.legacyPackages.x86_64-linux.hello
«derivation /nix/store/70vmydmb7hv290k7v459qlcqmnykpzxq-hello-2.10.drv»
I’ve actually used an empty NIX_PATH for a couple of days, but I’ve found myself using some legacy utilities like nix-shell once in a while and other tooling like nixpkgs-review does not work with flakes yet. This inconvenience wasn’t worth it for me and I went back to using NIX_PATH with flake inputs linked into /etc.
A few people and I discussed this on Discord a earlier. My side:
My <nixpkgs> is literally now just a wrapper around builtins.getFlake, so that nix-shell -p still works. It’s also a bit easier to use :l <nixpkgs> than :a (builtins.getFlake "flake:default").outputs.legacyPackages.${builtins.currentSystem}. If we can get nix-shell -p and nix repl to behave better with flakes, I think I can pretty much do without NIX_PATH.
@dramforever how do you accomplish this?
Sorry for bumping an old thread, I reached here via a web search after I failed to make my NixOS flake setup use the nixpkgs flake input as the nixPath argument. This may work for someone:
# /etc/nixos/flake.nix
    outputs = { self, nixpkgs }: {
      HOSTNAME = nixpkgs.lib.nixosSystem {
         system = "x86_64-linux";
         modules = [ (import ./configuration.nix nixpkgs.outPath) ];
# /etc/nixos/configuration.nix
# an argument that for nixPath for evaluation without internet
nixpkgs-path:
{ config, pkgs, options, lib, ... }:
  nix.nixPath = [
    # don't use `nixpkgs` as argument at the top - to not conflict with the configuration option nixpkgs
    "nixpkgs=${nixpkgs-path}"
Link to what was evaluated today for my system:
What exactly do you mean when you say “did not work”?
Did you see any error? Was the NIX_PATH not set properly? Anything else?
It’s weird, it didn’t evaluate earlier but now I can’t reproduce., because I didn’t notice I used both nixpkgs as an argument at the top of configuration.nix (and not nixpkgs-path) and nix confused it with the nixpkgs nixos option.
I edited the original message.
Nice!
I moved it to the flake.nix itself though, I prefer the locality:
      modules = [
        # Use the flake path for the nix path
        { nix.nixPath = [ "nixpkgs=${nixpkgs.outPath}" ]; }
        ./configuration.nix
Slight issue with that method. By doing "nixpkgs=${nixpkgs.outPath}", you’re hardcoding the path in the shell environment. So if you update nixpkgs, your open terminals will still see <nixpkgs> pointing to the old version.
Something similar I’m experimenting with that solves this:
  outputs = { nixpkgs, ... }@inputs: let
    flakeWrapper = name: builtins.toFile "${name}.nix" ''
      import (builtins.getFlake "${name}")
    registry = {
      nix.registry = nixpkgs.lib.mapAttrs (n: flake: { inherit flake; }) inputs;
      nix.nixPath = nixpkgs.lib.mapAttrsToList (name: _: "${name}=${flakeWrapper name}") inputs;
    nixosConfigurations.kruphix = nixpkgs.lib.nixosSystem {
      system = "aarch64-linux";
      modules = [
        ./machines/kruphix
        registry
I set the system flake registry so that builtins.getFlake "nixpkgs" always returns the nixpkgs that the current system was built with. And NIX_PATH is set to point <nixpkgs> to a wrapper file that will always import from builtins.getFlake, so that NIX_PATH doesn’t need to be updated for <nixpkgs> to be updated.
Only problem is that <nixpkgs> doesn’t actually point to a nixpkgs tree, so you can’t do stuff like <nixpkgs/nixos>. There’s workarounds though, like (import <nixpkgs> {}).path + "/nixos", but this isn’t a given for any flake, and it’s kinda ugly. So I dunno if I’m going to keep this.
Ah, old thread.
For the record at this point, this is how I am dealing with nix path and registry.
Extra feature: It allows me to browse my flake inputs code via /etc/nix/inputs/xyz
Ah, that’s very good. I like it
Thanks for this tip, yesterday I was running into this. I wound up pulling the store path of source and then imported that in nix-shell, but this is way cleaner.
Well - so what you’re saying is that open terminals need to access some global state.
Solution: put the flake sources in the system derivation and point the path to nixpkgs=/run/current-system/flakes/nixpkgs
I did it a little bit differently…
I used tmpfile.d to maintain symlinks to the correct “pins” and let my NIX_PATH point to those links:
It is not yet perfect, though the best I was able to come up with in a hurry. I’d like if there wasn’t a need to specify everything 3 times or so…
The more I think about it, the more sense it makes to me to tie the nixpkgs path to the current system, so that nix-shell and friends use what the rest of the current system is using.
Now I wonder how hard it is to express that in Nix.
