I tried to understand how home-manager works since I knew that NixOS module requires a schema that is as an attr set
imports = ...
options = ...
config = ...
(and there is a shorthand version).
so I realized that home-manager has to generate something like that. I played with it a bit:
a = inputs.home-manager.nixosModule { inherit lib pkgs; config = { home-manager = { }; }; utils = { }; };
b = builtins.head a.config.contents;
c = builtins.head a.config.contents).home-manager;
and I can see that it is generating { config = ... imports = ... }
I wonder is it possible to have both system config and user config (HM) in a single file?
In most cases this wouldn’t be needed but in some cases such freedom:
config = {
systemd.services.my-custom-user-app = {
home-manager.users.custom-app-user {
would be nice!
(this might not be the best example but I’m sure you can come up with some real use cases)
So is this even possible?
