Init System freedom on NixOS
As we know, NixOS is currently very intertwined with systemd. However, many people do not like or want to use systemd for different reasons.
How feasible would it be to untangle NixOS from systemd, to finally have the ability to choose a different init system on NixOS?
For example, one could set a boot.initSystem option in their NixOS config to choose their init system as such:
boot.initSystem.package = pkgs.systemd
boot.initSystem.package = pkgs.openrc
boot.initSystem.package = pkgs.runit
While this would probably break modular services, an idea I had was to have a high-level service configuration format in Nix that would eventually generate a service file for each init system.
Very difficult. You’d have to abandon and rewrite quite large portions of the nixos module code to actually get away from systemd. There have been efforts to essentially make a fork of nixos that works on another init system, but to my knowledge, none of them come anywhere close to the day-to-day usability of nixos.
This is in the ā€œwould be nice to have, but takes more work than anybody has been willing to put into itā€ category.
If you’re interested in this, I think your best bet would be to look into the currently-in-development ā€˜modular services’ ( NixOS Manual ). I haven’t used them, but AFAICT in theory that would allow you to move ā€˜most’(?) of the logic from the NixOS module to the nixpkgs modular service, and then build an alternative to NixOS that doesn’t use the NixOS modules but uses these modular services instead.
This looks promising, although I wonder if user services should be delegated to home-manager.
If all of the services.<insert thing here> could be migrated over to modular services, I feel like this whole init-freedom thing could become a lot more feasible.
An issue I do see, however, (not related to modular services) is having to port the Stage 1 boot over to all of the init systems. Since NixOS no longer uses the shell script-based stage 1, we’d have to move stage 1 over to every init system supported, or force boot.initrd.systemd.enable = false for users whose initsystem != systemd, and fall back to the old stage 1
nixpkgs and the nixos module system is modular enough that such an effort can be pioneered outside of nixpkgs.
There’s already sisox https://codeberg.org/amjoseph/sixos
Honestly I don’t really like the complexity supporting multiple init systems bring to NixOS. I’m not a fan of modular services either.
I think the idea is exactly that you could have a ā€˜modular service’ for something and then home-manager could leverage that and add any missing bits for running it as a user service.
I think that’s the idea, yeah.
I think NixOS should stick to systemd, and any alternative would live ā€˜outside’ of NixOS, bring its own stage 1, but potentially leverage modular services from nixpkgs.
(I haven’t used modular services yet so I don’t have an opinion on whether they’ll be good/successful, just pointing you at things that might be interesting to you and how I understand them)
I agree with this, yeah. I also haven’t had a chance to mess with modular services, so I’ll have to try them at some point
[quote=ā€œtejing, post:2, topic:78333ā€]
[/quote]
i guess it depends how you define ā€œusabilityā€, but i strongly disagree with that statement, so much that i would invite you to try finix on a spare device you might have.
personally i run finix on my laptop, spare laptop, home server, htpc, vps, and steam deck and find it just as usable as nixos in most cases. so please give finix a try to see if your opinion is supported by the reality of the situation if you’re up for it :man_bowing:
It’s true that I don’t have a good grasp of the usability of finix, but at the least, as I understand it, you lose most of the ready-made modules for various functionality that nixos would have. Simply because nowhere near as much integration effort has gone into finix.
That’s still a significant reduction in ā€œday-to-day usabilityā€, even if it’s at the level where a more experienced nixer could fill those gaps themselves as needed. For a more average nixos user, it’s a major issue, and I wouldn’t feel right pretending that it’s ready for just anyone to switch over to.
I am very interested in what becomes of finix, though, and I hope it might even develop into a more generalized abstraction over the init system at some point.
I have considered Finix and do want to switch to it at some point, but many of the ā€œservices.*ā€ things that I require don’t exist on Finix. I might spend an afternoon writing some services I use for Finix and contribute them, when i have time.
feel free to share what you are missing or feel would be useful to finix - thanks for any feedback!
I’ll create an issue on the GitHub repo, I’ve just got to go through my config to find what I actually need.
The amount of work required to untangle NixOS makes it politically infeasible.
For an s6-based system there is the original nixos-init-freedom and SLAM which is a fork of Finix with an init system abstraction and that leans harder into modular-services.
The problems are overstated for the case where a competent Nix user wants to run it on their own devices; for large-scale deployment with uneven user competence it’s more complicated.
Stage1 complexity comes from supporting many combinations of setups; taking a stage1 from finix and maybe adding one feature you miss, or even writing a full stage1 from scratch for the five systems you run is pretty simple. (I run my own stage1)
Many of NixOS services can be actually used from outside NixOS and with any or none service manager. lang-os/use-from-nixos.nix at 01af30fcecfea0371d78dc2f97d7fbd1b6d4b0c3 Ā· 7c6f434c/lang-os Ā· GitHub is what I use to evaluate a small NixOS config and take what is relevant for a service (in different combinations).
As stage1 complexity comes from the number of combinations, supporting better init systems is politically infeasible (because this increases complexity quite a lot). For services, though, the valuable part is config file generation and sometimes command-line options, which might eventually be shareable between different setups is modular services get used a bit more.
Note that modular services are mostly just a cleanup of what part of code does what, it does not meaningfully restrict what is done for systemd service files, so basically no one has sufficient stake to stop this; actual minor breakage cases have not previously slowed down code uniformisation efforts (except just enough to fix the specific breakage observed), so the precedents point towards this going through.
If the module systems abstraction actually grows beyond the current minimal scope, I’m worried that we just end with very poorly defined semantics for the various options. Right now you can easily learn about the semantics of the systemd.service module by looking up the option in the systemd documentation because the option names = the systemd config keys. In future will I have go digging through the system.service module everytime I want to learn what the options do, possibly in addition to docs for multiple init systems, because the options just map to whatever comes closest in the target init system? It wouldn’t surprise me.
I agree. I am in the opposite camp as I think systemd and Nix complements each other very well. I can’t imagine a more convenient way to configure systemd than using NixOS.
Unfeasible. Systemd brings so much to table that is well integrated within systemd that you would need to rebuild large parts of that to only reach parity and what do we gain at this point? More freedom to do everything we want ourselves, but we have to do everything ourselves!
We would also lose compatibility with many other major distros and some upstream work.
For modular service: I wouldn’t want any module I maintain to be part in that experiment just because I cannot guarantee that things would work equally and I do not want and largely also can’t allocate time to also maintain them or help with bugs.
IMO splitting the community in init systems will make support a lot harder and debugging things more demanding. I think it would require me to refuse support for anything other than systemd to not lose interest in the project or even get burned out.
As far as I understand, the idea of a modular init system, like what could be done with modular services, wouldn’t require individual package/service maintainers to keep up with internals of that abstraction - besides an initial migration to modular services, most of the burden would be in the code for maintaining abstractions of the init services
As someone who has used alternatives to systemd in the past, the way all their services work are fairly similar, I believe this could be technically viable (maybe not politically, but that’s another can of worms). That’s something I’d be interested to work on when I get more experience contributing to Nix.
Not really, because systemd service hardening exists (and frankly that’s the majority of the service definitions). Name another init that does that.
Not to mention many inits do not support basic functionality like restarting a service.
I personally think alternative inits are a waste of time, but I’m sure others feel the same about some of my pet projects :slight_smile:
That’s really not true. There’s a lot of different aspects of service management that differ quite a bit between service managers. For instance, systemd’s concept of ā€œunitsā€ is really unique because dependencies come in the form of both event propagation rules (Wants=, PartOf=, Triggers=, etc.) as well as job ordering queues (After=, Before=). The semantics of these things are very often critical to how the unit functions. For instance imagine a service that depends on a certain file system and should not listen on the network until the firewall starts. In systemd, you can just order a socket unit after the firewall unit, and you can have the socket unit trigger a service unit that depends on a mount unit. The socket isn’t listening until after the firewall is up, and a user connecting triggers an on-demand startup of the service, which queues jobs to mount the corresponding file system first after waiting for its block device to appear.
How would you do that with another service manager? I’m not saying you couldn’t; I’m just saying that with systemd every single behavior I just touched on is a property of a unit, whereas in other systems all of those things would be done completely differently. I’m sure that implementing this example is perfectly reasonable in your service manager of choice, but to say that the implementation would be fairly similar to how you do it with systemd is certainly not true. You would not be making things analogous to systemd units with properties analogous to systemd unit properties. macOS’s launchd, for instance, basically only has the socket-activated part of that equation. Others are more similar and others still are more different. The point is that there’s a wide variety of ways different systems do these things.
And that’s just dependency management. There’s all sorts of other massive differences. Bootup, UID allocation, sandboxing, runtime administration (e.g. the things switch-to-configuration does), device / driver management, and logging are all completely different depending on the service manager. There’s all kinds of differences that majorly influence how you implement your use case on that service manager.
I have become very convinced that you cannot make an abstraction layer for portability between service managers without that layer being so large and complicated as to constitute a service manager itself; it would just be a custom service manager implemented in terms of other service managers.
