I’m trying create nixpkgs environment that includes python but so that I could install packages with pip install --user
I’m using ~/.nixpkgs/config.nix
, which currently has something like:
packageOverrides = pkgs: with pkgs; {
myPackages = pkgs.buildEnv {
name = "my-packages";
ignoreCollisions = true;
paths = [
python3
which I can install with nix-env -i my-packages
. The problem is that installing binary packages with pip install
in this mode is impossible - the shared libraries used by binary modules are in Nix cache and not visible to pip-installed packages.
I tried different approach:
paths = [
(pkgs.python3.withPackages (
ps: with ps; [
numpy
matplotlib
This way installed python already has needed packages (e.g. numpy
and matploblib
) but it’s a virtualenv environment so I can’t use pip
with it.
What I want to have python with some packages specified in Nix config file but installed as non-virtualenv so that I could add packages I need with pip install
. Is it possible?
