I wanted to install pygraphviz using poetry, but I got the following error:
$ poetry add pygraphviz
pygraphviz/graphviz_wrap.c:3023:10: 致命的エラー: graphviz/cgraph.h: No such file or directory
3023 | #include "graphviz/cgraph.h"
コンパイルを停止しました。
error: command '/home/z/.nix-profile/bin/gcc' failed with exit code 1
at /nix/store/aasf21i1lqwa7gl5nbxg9hrq775pdsl9-python3.12-poetry-1.8.4/lib/python3.12/site-packages/poetry/installation/chef.py:164 in _prepare
160│
161│ error = ChefBuildError("\n\n".join(message_parts))
162│
163│ if error is not None:
→ 164│ raise error from None
165│
166│ return path
167│
168│ def _prepare_sdist(self, archive: Path, destination: Path | None = None) -> Path:
Note: This error originates from the build backend, and is likely not a problem with poetry but with pygraphviz (1.14) not supporting PEP 517 builds. You can verify this by running 'pip wheel --no-cache-dir --use-pep517 "pygraphviz (==1.14)"'.
My understanding is that envfs and nix-ld are tools for binaries and libraries, respectively, and could not be used to resolve this error which is for a source file. Is it correct?
Anyway I ran the following command and I still got and error:
(Note that dot
is one of the binaries in pkgs.graphviz)
$ export C_INCLUDE_PATH=$(nix-store -r $(which dot))/include
gcc -shared -L/nix/store/eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee-bzip2-1.0.8/lib -L/nix/store/eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee-expat-2.6.4/lib -L/nix/store/eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee-libffi-3.4.6/lib -L/nix/store/a7x8s7d3bhn41dqrai6nf5xszizb7fm2-libxcrypt-4.4.36/lib -L/nix/store/eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee-mpdecimal-4.0.0/lib -L/nix/store/eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee-ncurses-6.4.20221231/lib -L/nix/store/eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee-openssl-3.3.2/lib -L/nix/store/eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee-sqlite-3.46.1/lib -L/nix/store/eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee-xz-5.6.3/lib -L/nix/store/eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee-zlib-1.3.1/lib -L/nix/store/78mhfhbhfhvx95hjv9hkjx8m0vadynjv-tzdata-2024b/lib -L/nix/store/eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee-gdbm-1.24-lib/lib -L/nix/store/eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee-readline-8.2p13/lib -L/nix/store/eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee-bzip2-1.0.8/lib -L/nix/store/eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee-expat-2.6.4/lib -L/nix/store/eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee-libffi-3.4.6/lib -L/nix/store/a7x8s7d3bhn41dqrai6nf5xszizb7fm2-libxcrypt-4.4.36/lib -L/nix/store/eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee-mpdecimal-4.0.0/lib -L/nix/store/eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee-ncurses-6.4.20221231/lib -L/nix/store/eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee-openssl-3.3.2/lib -L/nix/store/eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee-sqlite-3.46.1/lib -L/nix/store/eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee-xz-5.6.3/lib -L/nix/store/eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee-zlib-1.3.1/lib -L/nix/store/78mhfhbhfhvx95hjv9hkjx8m0vadynjv-tzdata-2024b/lib -L/nix/store/eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee-gdbm-1.24-lib/lib -L/nix/store/eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee-readline-8.2p13/lib build/temp.linux-x86_64-cpython-312/pygraphviz/graphviz_wrap.o -L/nix/store/kjgslpdqchx1sm7a5h9xibi5rrqcqfnl-python3-3.12.8/lib -lcdt -lcgraph -lgvc -o build/lib.linux-x86_64-cpython-312/pygraphviz/_graphviz.cpython-312-x86_64-linux-gnu.so
/nix/store/vk4mlknqk9yjbqa68a7rvpfxfdw3rad7-binutils-2.43.1/bin/ld: -lcdt が見つかりません: No such file or directory
/nix/store/vk4mlknqk9yjbqa68a7rvpfxfdw3rad7-binutils-2.43.1/bin/ld: -lcgraph が見つかりません: No such file or directory
/nix/store/vk4mlknqk9yjbqa68a7rvpfxfdw3rad7-binutils-2.43.1/bin/ld: -lgvc が見つかりません: No such file or directory
collect2: エラー: ld はステータス 1 で終了しました
I added graphviz
to nix-ld.libraries
but it has no effect (same error occurs) while I can confirm that import numpy
does not raise error (both after running export LD_LIBRARY_PATH = $NIX_LD_LIBRARY_PATH
). (Why?)
programs.nix-ld = {
libraries = (with pkgs; [
zlib
zstd
stdenv.cc.cc
curl
openssl
attr
libssh
bzip2
libxml2
acl
libsodium
util-linux
xz
systemd
# pygraphviz-specific deps
graphviz
coreutils
So I had to set $LIBRARY_PATH
as well.
$ export LIBRARY_PATH=$(nix-store -r $(which dot))/lib
$ poetry add pygraphviz==1.10
Updating dependencies
Resolving dependencies... (0.7s)
Package operations: 0 installs, 1 update, 0 removals
- Downgrading pygraphviz (1.14 -> 1.10)
Writing lock file
The above method worked to a point, but is there a better way to do this?
