Is multi-user installation useless if I have no plans on using my mac with multi users?
I installed nix to my MacBook Pro with daemon option.
Some configuration (such as binary cache) is not changeable unless I add my user to trusted users, so it’s secure than single-user installation in some way?
I would believe that a daemon running as root can isolate builds better, so it should be more robust w.r.t. builds looking at the global system too much.
The daemon is also able to build multiple packages at once, which I don’t think happens in a single user install.
FWIW, multi-user will be the only option if/when darwin: encrypt nix volume if filevault is enabled by abathur · Pull Request #4289 · NixOS/nix · GitHub is merged and makes its way into a release.
I’m not sure whether on macOS builds are sandboxed at all, but on Linux the sandbox is only available in multi-user mode.
