Hi,
I have a background in puppet, and for deploying python applications am used to just creating a venv, pulling a package from pypi, and wrapping it in a systemd unit. Now that I’m slowly experimenting a bit with nixos for personal use, I’m running into a first big hurdle that I can’t seem to figure out no matter how much documentation I read. From what I understand, the nix-way to solve this issue of deploying my application, is to create a ‘derivation’.
My current set-up looks like this (simplified a lot)
Directory structure:
modules/dungeondice/default.nix
modules/dungeondice/pythonapplication.nix
flake.nix
Where In my flake.nix I take care of creating hosts and importing modules/dungeondice
My default.nix:
{ pkgs, ... }:
dungeondice = pkgs.callPackage ./pythonapplication.nix {};
environment.systemPackages = [ dungeondice ];
pythonapplication.nix:
lib,
python3Packages,
python3Packages.buildPythonApplication rec {
pname = "dungeondice";
version = "1.3.3";
pyproject = true;
src = with python3Packages; fetchPypi {
inherit pname version;
hash = "sha256-0dylwdbkickyn9nhxlsrcj7k3brlg1lh5k073w0shjxhwkjh5g4c";
nativeBuildInputs = with python3Packages; [
hatchling
propagatedBuildInputs = with python3Packages; [
discordpy
python-dotenv
meta = {
description = "Dice rolling bot for D&D games on discord.";
homepage = "https://github.com/jwizzle/dungeondice";
license = lib.licenses.agpl3Only;
So from what I understand should be happening here, is that callPackage passes along python3Packagesto pythonappplication.nix. That builds my application. And this in turn returns a reference to the built thing. Which in turn I can add to my systemPackages to make it available on my system. (please already correct me if my mental model is incorrect here of what should be happening).
Now when I use `sudo nixos-rebuild switch --flake ~/.config/home-manager#jwizz-desktop --verbose` I get some output that I can’t work with at all:
File "/nix/store/qbrx5yh7w11zaqrr0kxdgszz0svr3421-nixos-rebuild-ng-25.11/lib/python3.13/site-packages/nixos_rebuild/__init__.py", line 352, in main
execute(sys.argv)
File "/nix/store/qbrx5yh7w11zaqrr0kxdgszz0svr3421-nixos-rebuild-ng-25.11/lib/python3.13/site-packages/nixos_rebuild/__init__.py", line 315, in execute
services.build_and_activate_system(
action=action,
...<6 lines>...
grouped_nix_args=grouped_nix_args,
File "/nix/store/qbrx5yh7w11zaqrr0kxdgszz0svr3421-nixos-rebuild-ng-25.11/lib/python3.13/site-packages/nixos_rebuild/services.py", line 301, in build_and_activate_system
path_to_config = _build_system(
attr=attr,
...<5 lines>...
File "/nix/store/qbrx5yh7w11zaqrr0kxdgszz0svr3421-nixos-rebuild-ng-25.11/lib/python3.13/site-packages/nixos_rebuild/services.py", line 173, in _build_system
path_to_config = nix.build_flake(
attr,
...<2 lines>...
| grouped_nix_args.flake_build_flags,
File "/nix/store/qbrx5yh7w11zaqrr0kxdgszz0svr3421-nixos-rebuild-ng-25.11/lib/python3.13/site-packages/nixos_rebuild/nix.py", line 87, in build_flake
r = run_wrapper(run_args, stdout=PIPE)
File "/nix/store/qbrx5yh7w11zaqrr0kxdgszz0svr3421-nixos-rebuild-ng-25.11/lib/python3.13/site-packages/nixos_rebuild/process.py", line 137, in run_wrapper
r = subprocess.run(
run_args,
...<7 lines>...
**kwargs,
File "/nix/store/cdaifv92znxy5ai4sawricjl0p5b9sgf-python3-3.13.11/lib/python3.13/subprocess.py", line 577, in run
raise CalledProcessError(retcode, process.args,
output=stdout, stderr=stderr)
subprocess.CalledProcessError: Command '['nix', '--extra-experimental-features', 'nix-command flakes', 'build', '--print-out-paths', '/home/jwiersma/.config/home-manager#nixosConfigurations."jwizz-desktop".config.system.build.toplevel', '--no-link', '-v']' returned non-zero exit status 1.
Could someone help me on my way to find out what is going on here?
