following settings cause issues
hardware.bluetooth = {
settings = {
DiscoverableTimeout = 1;
Privacy = "limited-device";
error: A definition for option `hardware.bluetooth.settings.DiscoverableTimeout' is not of type `section of an INI file (attrs of INI atom (null, bool, int, float or string))'. TypeError: Definition values:
- In `/etc/nixos/hardware-configuration.nix': 1
# after changing it to "1"
- In `/etc/nixos/hardware-configuration.nix': "1"
# after commenting that out, next one causes issues
error: A definition for option `hardware.bluetooth.settings.Privacy' is not of type `section of an INI file (attrs of INI atom (null, bool, int, float or string))'. TypeError: Definition values:
- In `/etc/nixos/hardware-configuration.nix': "limited-device"
