Issues with building and running Raspberry 4 image
Hello - I am very new to NixOs and maybe it is an obvious issue but I can’t get round it and it drives me crazy.
I am trying to do the initial build of RPI4 images which I downloaded from here - Hydra - Job nixos:trunk-combined:nixos.sd_image_raspberrypi4.aarch64-linux
I burned it to the SD card, edited cmdline.txt file and added the following line:
console=ttyS0,115200n8 console=ttyAMA0,115200n8 console=tty0
so I could connect to RPI console with serial cable.
so far all good - I am able to connect to nixos promt with nixos account.
next step I added /etc/nixos/configuration.nix which looks like this:
{ config, pkgs, … }:
imports =
boot.loader.grub.enable = false;
boot.loader.generic-extlinux-compatible.enable = true;
fileSystems = {
“/boot” = {
device = “/dev/disk/by-label/NIXOS_BOOT”;
fsType = “vfat”;
device = “/dev/disk/by-label/NIXOS_SD”;
fsType = “ext4”;
wget vim
system.stateVersion = “20.03”; # Did you read the comment?
and run nixos-rebuild switch.
the build fails and drops me into emergency mode which shows that ‘The process /run/current-system/sw/bin/plymouth could not be executed’
ok - found this issue https://github.com/NixOS/nixpkgs/issues/23050
which seems to suggest that the issue is related to not mounted /boot partion?
not sure why - I can see /boot with df -h /boot which points to “/dev/disk/by-label/NIXOS_BOOT”; just as specified by the configuration.nix
adding option
options = [“nofail”];
to /boot partition and rebuilding takes me further but then none of the options which I add to configuration.nix or add interactively hold after the restart.
e.g even if I add password for nixos account with passwd and even though I have
in the configuration.nix file
sshd doesn’t work after restart and OS prompt says that ‘nixos’ account has an empty password.
all this feels like the issue with boot partition but I have no idea how to confirm this or fix it.
does anybody has any experience with running NixOs on RPI4?
this page raspberrypi :: Lunar Computer — Tech Blog and Tutorials has some instructions but they are pretty basic and I have the same issue with running the first build
