hello I’m trying to build the example app for this project but I cannot get it to work. I receive this error
ld: warning: object file (/nix/store/mrrc440cshmc13rqqj4405jbqnklf4ja-Libsystem-osx-10.12.6/lib/crt1.10.6.o) was built for newer OSX version (10.10) than being linked (10.7)
ld: file not found: /usr/lib/system/libcache.dylib for architecture x86_64
clang-7: error: linker command failed with exit code 1 (use -v to see invocation)
make[1]: *** [tools/icu/icupkg.host.mk:183: /private/tmp/nix-build-nodejs-slim-8.15.1.drv-0/node-v8.15.1/out/Release/icupkg] Error 1
rm b4e72878147acdb34471d8434572918605a79e00.intermediate
make: *** [Makefile:88: node] Error 2
error: builder for '/nix/store/2sp0y73vp4jqdmmxkgi629wrccb7mjaf-nodejs-slim-8.15.1.drv' failed with exit code 2;
last 10 log lines:
> clang++ '-D_DARWIN_USE_64_BIT_INODE=1' '-DUCONFIG_NO_SERVICE=1' '-DUCONFIG_NO_REGULAR_EXPRESSIONS=1' '-DU_ENABLE_DYLOAD=0' '-DU_STATIC_IMPLEMENTATION=1' '-DU_HAVE_STD_STRING=0' '-DUCONFIG_NO_BREAK_ITERATION=0' -I/nix/store/xllycfvg6yh6wgn57z45qcn4n5k495ym-zlib-1.2.11-dev/include -I/nix/store/vmrqpnwm5bh89n58v9n2afxbzxrwwz48-libuv-1.28.0/include -I/nix/store/gq3f7y4jmclsxiy1lyrzgs0582adqpgk-openssl-1.0.2r-dev/include -I../deps/icu-small/source/common -I../deps/icu-small/source/i18n -I../deps/icu-small/source/tools/toolutil -Os -gdwarf-2 -mmacosx-version-min=10.7 -arch x86_64 -Wall -Wendif-labels -W -Wno-unused-parameter -std=gnu++0x -stdlib=libc++ -fno-rtti -fno-exceptions -fno-threadsafe-statics -fno-strict-aliasing -MMD -MF /private/tmp/nix-build-nodejs-slim-8.15.1.drv-0/node-v8.15.1/out/Release/.deps//private/tmp/nix-build-nodejs-slim-8.15.1.drv-0/node-v8.15.1/out/Release/obj.host/iculslocs/tools/icu/no-op.o.d.raw -c -o /private/tmp/nix-build-nodejs-slim-8.15.1.drv-0/node-v8.15.1/out/Release/obj.host/iculslocs/tools/icu/no-op.o ../tools/icu/no-op.cc
> touch /private/tmp/nix-build-nodejs-slim-8.15.1.drv-0/node-v8.15.1/out/Release/obj.host/tools/icu/icui18n.stamp
> touch /private/tmp/nix-build-nodejs-slim-8.15.1.drv-0/node-v8.15.1/out/Release/obj.host/tools/icu/icuuc.stamp
> clang++ -Wl,-no_pie -Wl,-search_paths_first -mmacosx-version-min=10.7 -arch x86_64 -L/private/tmp/nix-build-nodejs-slim-8.15.1.drv-0/node-v8.15.1/out/Release -stdlib=libc++ -o "/private/tmp/nix-build-nodejs-slim-8.15.1.drv-0/node-v8.15.1/out/Release/icupkg" /private/tmp/nix-build-nodejs-slim-8.15.1.drv-0/node-v8.15.1/out/Release/obj.host/icupkg/deps/icu-small/source/tools/icupkg/icupkg.o /private/tmp/nix-build-nodejs-slim-8.15.1.drv-0/node-v8.15.1/out/Release/obj.host/icupkg/tools/icu/no-op.o /private/tmp/nix-build-nodejs-slim-8.15.1.drv-0/node-v8.15.1/out/Release/obj.host/tools/icu/libicutools.a -L/nix/store/nz18qdq9yv7hd9nyf7r8fn7n48w27hjs-zlib-1.2.11/lib -lz -L/nix/store/vmrqpnwm5bh89n58v9n2afxbzxrwwz48-libuv-1.28.0/lib -luv -L/nix/store/s81dq8aqal5hjwkn6wndaklsnbyq60z1-openssl-1.0.2r/lib -lcrypto -lssl
For full logs, run 'nix-store -l /nix/store/2sp0y73vp4jqdmmxkgi629wrccb7mjaf-nodejs-slim-8.15.1.drv'.
error: 1 dependencies of derivation '/nix/store/sj54v02dqz4bg13j6f7fjpwfi9mh56w6-app-0.1.0.0.drv' failed to build
with (import (builtins.fetchGit {
url = "https://github.com/dmjio/miso.git";
ref = "refs/tags/1.8";
pkgs.haskell.packages.ghcjs.callCabal2nix "app" ./. {}
- system: `"x86_64-darwin"`
- host os: `Darwin 21.6.0, macOS 10.16`
- multi-user?: `yes`
- sandbox: `no`
- version: `nix-env (Nix) 2.13.3`
- channels(root): `"nixpkgs"`
- nixpkgs: `/nix/var/nix/profiles/per-user/root/channels/nixpkgs`
any help would be appreciated.
