Hello everyone.
I’m trying to access luajit packages I added to my home manager, but I get the following error:
lua: module 'luv' not found:
no field package.preload['luv']
no file './luv.lua'
no file '/nix/store/s2q178smkfc62l0lg2ir8hp3qqyyc8yl-luajit-2.1.0-2020-12-28/share/luajit-2.1.0-beta3/luv.lua'
no file '/usr/local/share/lua/5.1/luv.lua'
no file '/usr/local/share/lua/5.1/luv/init.lua'
no file '/nix/store/s2q178smkfc62l0lg2ir8hp3qqyyc8yl-luajit-2.1.0-2020-12-28/share/lua/5.1/luv.lua'
no file '/nix/store/s2q178smkfc62l0lg2ir8hp3qqyyc8yl-luajit-2.1.0-2020-12-28/share/lua/5.1/luv/init.lua'
no file './luv.so'
no file '/usr/local/lib/lua/5.1/luv.so'
no file '/nix/store/s2q178smkfc62l0lg2ir8hp3qqyyc8yl-luajit-2.1.0-2020-12-28/lib/lua/5.1/luv.so'
no file '/usr/local/lib/lua/5.1/loadall.so'
stack traceback:
[C]: in function 'require'
[C]: at 0x004062c0
zsh: exit 1 ptf
As it seem packages are either not installed or not in lua path, is there a workaround to access those packages or to put them in lua runtime, or should I install them some different way?
{ config, pkgs, libs, ... }:
home.packages = with pkgs; [
luajit
luajitPackages.luafilesystem
luajitPackages.luv
luajitPackages.cjson
luajitPackages.stdlib
luajitPackages.inspect
Thanks
