I’m trying to set up wireguard. I’m unable to make it connect. The wiki page appears to be partially wrong. And I’m not particularly knowledgeable in the networking department.
I’ve tried both the “wireguard” and “wg-quick” methods of setting it up. The “wireguard” way seems to be known to actually be flawed in the wiki, because redirecting all traffic via 0.0.0.0/0
does not work.
Anyway, my setup is a private network behind DDNS, which may be an additional hurdle. So far, the output of wg show
on clients indicates that they can resolve the domain name I use in place of an IP to some IPv6 address, though that address is not the same as I see using services like What is My IP Address (is that expected?).
Currently, I’m trying to make the wg-quick method from the wiki work. This is the config:
pkgs,
lib,
config,
# Not sure I want / need that but I copied from wiki just in case
services.dnsmasq = {
extraConfig = ''
interface=wg0
networking.nat = {
enableIPv6 = true;
# This is a wifi stick for now. That's correct to use here, no?!
externalInterface = "wlp0s29u1u1i2";
internalInterfaces = ["wg0"];
networking.firewall = {
allowedTCPPorts = [53];
allowedUDPPorts = [53 51820];
networking.wg-quick.interfaces = {
wg0 = {
# Determines the IP/IPv6 address and subnet of the client's end of the tunnel interface
address = ["10.0.0.1/24" "fdc9:281f:04d7:9ee9::1/64"]; # blind copy from wiki
listenPort = 51820;
privateKeyFile = "/my/private/key/file";
postUp = ''
${pkgs.iptables}/bin/iptables -A FORWARD -i wg0 -j ACCEPT
${pkgs.iptables}/bin/iptables -t nat -A POSTROUTING -s 10.0.0.1/24 -o wlp0s29u1u1i2 -j MASQUERADE
${pkgs.iptables}/bin/ip6tables -A FORWARD -i wg0 -j ACCEPT
${pkgs.iptables}/bin/ip6tables -t nat -A POSTROUTING -s fdc9:281f:04d7:9ee9::1/64 -o wlp0s29u1u1i2 -j MASQUERADE
preDown = ''
${pkgs.iptables}/bin/iptables -D FORWARD -i wg0 -j ACCEPT
${pkgs.iptables}/bin/iptables -t nat -D POSTROUTING -s 10.0.0.1/24 -o wlp0s29u1u1i2 -j MASQUERADE
${pkgs.iptables}/bin/ip6tables -D FORWARD -i wg0 -j ACCEPT
${pkgs.iptables}/bin/ip6tables -t nat -D POSTROUTING -s fdc9:281f:04d7:9ee9::1/64 -o wlp0s29u1u1i2 -j MASQUERADE
peers = [
# Laptop
publicKey = "hirf...akQ=";
allowedIPs = ["10.0.0.4/32"];
# Phone
publicKey = "dL2...nA=";
allowedIPs = ["10.100.0.2/32"];
The corresponding “Laptop” client config is
config,
lib,
allowedUDPPorts = [51820];
wg0 = {
address = ["10.100.0.4/24"];
privateKeyFile = "/private/key/file";
peers = [
publicKey = "2M...0=";
allowedIPs = ["0.0.0.0/0" "::/0"];
endpoint = "my-ddns-domain:51820";
persistentKeepalive = 25;
This does not establish a connection. In fact, it breaks internet access on the client completely. So I suspect the problem be on the server. The phone (using the wireguard android app) has the same problem.
Does somebody spot the problem in here?
