I just discovered makeSetupHook
and an interesting use for it in shell.nix files.
In a few projects, I had shell.nix files that used shellHook
to run helper scripts I’d tucked away in a ./nix
subdirectory.
For example, in a few cases I wanted to spin up a database upon entering the shell and spin it down upon exiting:
with pkgs; mkShell {
name = "foo";
buildInputs = [ postgresql ];
shellHook = ''
trap "'$PWD/nix/pgSetup' remove" EXIT
nix/pgSetup
One problem with this approach is it relies on the presence of these random shell scripts that are not represented as part of the derivation itself. Another problem is that I end up duplicating these scripts across projects.
I was going to address this by packing the helper scripts with writeShellScript
, but then I noticed makeSetupHook
. It sounds like it was designed with a different use-case in mind, but it lets me package the setup script and automatically runs it upon entering the shell as long as I include it in my buildInputs
pgSetup = with pkgs; makeSetupHook { } ./nix/pgSetup;
in with pkgs; mkShell {
name = "foo";
buildInputs = [ postgresql pgSetup ];
shellHook = ''
trap '${pgSetup}/nix-support/setup-hook remove' EXIT
So ./nix/pgSetup
needs to exist relative to the derivation, but it doesn’t need to exist relative to nix-shell invocation, allowing, for example, using it like:
nix-shell https://github.com/path/to/nix-shells/archive/master.tar.gz -A foo
I might actually switch to using writeShellScript
, as it offers more flexibility and control, but I thought this was interesting.
