Microsoft Surface Pro 4 (2015) wifi failure after suspend
Hello all! Recently switched to NixOS on my Surface Pro 4 and every time my device switches to sleep mode, I cannot get it to reconnect to my WiFi access point afterward. NMTUI still sees my WiFi interface but any attempt at reconnecting fails. Turning off Wifi from the Gnome Interface removes the WiFi interface entirely.
What I have tried already:
  • disabled NetworkManager wifi powersave option (did not do anything)
  • added the module from the nixos-hardware repo (introduced its own slew of problem so I did not have the opportunity to see if it fixed anything and I rolled back to a previous generation)
  • tried to hot remove and reload the drivers mwifiex_pcie and mwifie (failed and introduced further issues that prevented a proper reboot and forced me to long press the shutdown button instead)
I hope that other people that ever had those problems have a solution because I am all out of idea right now.
I have included some info I believe are relevant below, available to provide more.
Thanks for the help!
NixOS version: 26.05.5591.fd1462031fde (Yarara)
Kernel version: 6.18.39
Hardware controller info : 01:00.0 Ethernet controller: Marvell Technology Group Ltd. 88W8897 [AVASTAR] 802.11ac Wireless
Relevant drivers (?): cfg80211, mwifiex, mwifiex_pcie
Current network configuration:
  networking = {
    hostName = "[DEVICENAME]" # Define your hostname
    networkmanager = {
      # Setup network manager
      wifi.powersave = false;
Truncated dmesg output:
[ 4660.254909] mwifiex_pcie 0000:01:00.0: info: associated to bssid 3a:07:16:d2:43:50 successfully
[ 4660.304377] mwifiex_pcie 0000:01:00.0: key: send EAPOL to 3a:07:16:d2:43:50
[ 4660.308055] mwifiex_pcie 0000:01:00.0: key: send EAPOL to 3a:07:16:d2:43:50
[ 5694.118778] usb 1-7: USB disconnect, device number 4
[ 5695.111773] mwifiex_pcie 0000:01:00.0: info: successfully disconnected from 3a:07:16:d2:43:50: reason code 3
[ 5695.658288] PM: suspend entry (s2idle)
[ 5696.289630] Filesystems sync: 0.631 seconds
[ 5696.396446] Freezing user space processes
[ 5696.428985] Freezing user space processes completed (elapsed 0.032 seconds)
[ 5696.428992] OOM killer disabled.
[ 5696.428993] Freezing remaining freezable tasks
[ 5696.430261] Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
[ 5696.430267] printk: Suspending console(s) (use no_console_suspend to debug)
[ 5696.568772] intel_pch_thermal 0000:00:14.2: CPU-PCH is cool [42C]
[49211.413955] mwifiex_pcie 0000:01:00.0: Unable to change power state from D3hot to D0, device inaccessible
[49211.455483] surface_acpi_notify MSHW0091:00: rqst: device is suspended, not executing
[49211.457348] surface_acpi_notify MSHW0091:00: ETWL(0x01, 0x02): RQST(2, 13, 1) error: 5
[49211.458416] surface_acpi_notify MSHW0091:00: rqst: device is suspended, not executing
[49211.460185] surface_acpi_notify MSHW0091:00: ETWL(0x01, 0x02): RQST(2, 13, 1) error: 5
[49211.460608] surface_acpi_notify MSHW0091:00: rqst: device is suspended, not executing
[49211.462879] surface_acpi_notify MSHW0091:00: ETWL(0x01, 0x02): RQST(2, 13, 1) error: 5
[49211.543002] dptf_power INT3407:00: Unsupported event [0x82]
[49211.553701] surface_serial_hub serial0-0: rx: parser: invalid start of frame, skipping
[49211.554676] surface_serial_hub serial0-0: rx: parser: invalid start of frame, skipping
[49211.555640] surface_serial_hub serial0-0: rx: parser: invalid start of frame, skipping
[49211.556595] surface_serial_hub serial0-0: rx: parser: invalid start of frame, skipping
[49211.557549] surface_serial_hub serial0-0: rx: parser: invalid start of frame, skipping
[49211.558952] OOM killer enabled.
[49211.558955] Restarting tasks: Starting
[49211.559448] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_ops [i915])
[49211.561149] Restarting tasks: Done
[49211.561159] efivarfs: resyncing variable state
[49211.567157] efivarfs: finished resyncing variable state
[49211.567184] random: crng reseeded on system resumption
[49211.808920] mwifiex_pcie 0000:01:00.0: Firmware didn't wake up
[49214.053383] usb 1-7: new full-speed USB device number 5 using xhci_hcd
[49214.180630] usb 1-7: New USB device found, idVendor=045e, idProduct=07e8, bcdDevice= 2.07
[49214.180637] usb 1-7: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[49214.180639] usb 1-7: Product: Surface Type Cover
[49214.180641] usb 1-7: Manufacturer: Microsoft
[49214.186723] input: Microsoft Surface Type Cover Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/0003:045E:07E8.0004/input/input31
[49214.249887] input: Microsoft Surface Type Cover Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/0003:045E:07E8.0004/input/input32
[49214.250243] input: Microsoft Surface Type Cover UNKNOWN as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/0003:045E:07E8.0004/input/input33
[49214.250448] input: Microsoft Surface Type Cover Touchpad as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/0003:045E:07E8.0004/input/input34
[49214.250730] input: Microsoft Surface Type Cover UNKNOWN as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/0003:045E:07E8.0004/input/input35
[49214.250832] input: Microsoft Surface Type Cover UNKNOWN as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/0003:045E:07E8.0004/input/input36
[49214.250906] input: Microsoft Surface Type Cover UNKNOWN as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/0003:045E:07E8.0004/input/input37
[49214.251056] hid-multitouch 0003:045E:07E8.0004: input,hiddev96,hidraw0: USB HID v1.11 Keyboard [Microsoft Surface Type Cover] on usb-0000:00:14.0-7/input0
[49214.486254] mwifiex_pcie 0000:01:00.0: Firmware wakeup failed
[49214.486298] mwifiex_pcie 0000:01:00.0: PREP_CMD: FW in reset state
[49214.486374] mwifiex_pcie 0000:01:00.0: info: shutdown mwifiex...
[49214.486684] mwifiex_pcie 0000:01:00.0: PREP_CMD: card is removed
[49214.503311] mwifiex_pcie 0000:01:00.0: Using reset_d3cold quirk to perform FW reset
[49214.503316] mwifiex_pcie 0000:01:00.0: putting into D3cold...
[49214.514651] pcieport 0000:00:1c.0: putting into D3cold...
[49214.552333] surface_serial_hub serial0-0: rx: parser: invalid start of frame, skipping
[49214.559815] pcieport 0000:00:1c.0: putting into D0...
[49214.568613] PM: suspend exit
[49214.698510] mwifiex_pcie 0000:01:00.0: putting into D0...
[49214.698534] mwifiex_pcie 0000:01:00.0: Unable to change power state from D3cold to D0, device inaccessible
[49214.698547] mwifiex_pcie 0000:01:00.0: Unable to change power state from D3cold to D0, device inaccessible
[49214.745811] pcieport 0000:00:1c.0: unlocked secondary bus reset via: __pci_reset_function_locked+0x4c/0xd0
[49214.888262] mwifiex_pcie 0000:01:00.0: WLAN FW already running! Skip FW dnld
[49214.888269] mwifiex_pcie 0000:01:00.0: WLAN FW is active
[49214.889117] mwifiex_pcie 0000:01:00.0: event: unknown event id: 0xbb00
[49214.889131] mwifiex_pcie 0000:01:00.0: event: unknown event id: 0xf0e3
[49214.889140] mwifiex_pcie 0000:01:00.0: event: unknown event id: 0x4006
[49214.889149] mwifiex_pcie 0000:01:00.0: event: unknown event id: 0x0
[49214.889158] mwifiex_pcie 0000:01:00.0: event: unknown event id: 0xfd7a
[49214.889167] mwifiex_pcie 0000:01:00.0: event: unknown event id: 0x0
[49214.889175] mwifiex_pcie 0000:01:00.0: event: unknown event id: 0x0
[49214.889183] mwifiex_pcie 0000:01:00.0: event: unknown event id: 0x0
[49214.889191] mwifiex_pcie 0000:01:00.0: event: unknown event id: 0xbb00
[49214.889199] mwifiex_pcie 0000:01:00.0: event: unknown event id: 0xf0e3
[49214.889207] mwifiex_pcie 0000:01:00.0: event: unknown event id: 0x4006
[49214.889216] mwifiex_pcie 0000:01:00.0: event: unknown event id: 0x0
[49214.945545] mwifiex_pcie 0000:01:00.0: host_mlme: disable, key_api: 2
[49215.072540] mwifiex_pcie 0000:01:00.0: event: unknown event id: 0xfd7a
[49215.072634] mwifiex_pcie 0000:01:00.0: event: unknown event id: 0x0
[49215.072643] mwifiex_pcie 0000:01:00.0: event: unknown event id: 0x0
[49215.072650] mwifiex_pcie 0000:01:00.0: event: unknown event id: 0x0
[49215.102244] mwifiex_pcie 0000:01:00.0: info: MWIFIEX VERSION: mwifiex 1.0 (15.68.19.p21)
[49215.102250] mwifiex_pcie 0000:01:00.0: driver_version = mwifiex 1.0 (15.68.19.p21)
[49215.299325] mwifiex_pcie 0000:01:00.0 wlp1s0: renamed from mlan0
[49223.801063] dptf_power INT3407:00: Unsupported event [0x82]
[49229.941326] mwifiex_pcie 0000:01:00.0: info: trying to associate to bssid 3a:07:16:d2:43:54
[49229.986920] mwifiex_pcie 0000:01:00.0: assoc: associated with 3a:07:16:d2:43:54
[49229.986958] mwifiex_pcie 0000:01:00.0: info: associated to bssid 3a:07:16:d2:43:54 successfully
[49229.994413] mwifiex_pcie 0000:01:00.0: key: send EAPOL to 3a:07:16:d2:43:54
[49230.997553] mwifiex_pcie 0000:01:00.0: key: send EAPOL to 3a:07:16:d2:43:54
[49232.007945] mwifiex_pcie 0000:01:00.0: key: send EAPOL to 3a:07:16:d2:43:54
[49233.000056] mwifiex_pcie 0000:01:00.0: key: send EAPOL to 3a:07:16:d2:43:54
[49233.998313] mwifiex_pcie 0000:01:00.0: info: successfully disconnected from 3a:07:16:d2:43:54: reason code 15
[49284.184238] mwifiex_pcie 0000:01:00.0: cmd_wait_q terminated: -110
[49296.472445] mwifiex_pcie 0000:01:00.0: cmd_wait_q terminated: -110
[49296.472455] mwifiex_pcie 0000:01:00.0: set mac address failed: ret=-110
[49308.760953] mwifiex_pcie 0000:01:00.0: cmd_wait_q terminated: -110
[49321.050551] mwifiex_pcie 0000:01:00.0: cmd_wait_q terminated: -110
[49343.066712] mwifiex_pcie 0000:01:00.0: cmd_wait_q terminated: -110
[49355.354583] mwifiex_pcie 0000:01:00.0: cmd_wait_q terminated: -110
[49367.643279] mwifiex_pcie 0000:01:00.0: cmd_wait_q terminated: -110
NetworkManager journal logs
juil. 31 12:13:03 [DEVICENAME] NetworkManager[821]: <warn>  [1785492783.5411] device (p2p-dev-wlp1s0): error setting IPv4 forwarding to '0': Resource temporarily unavailable
juil. 31 12:13:49 [DEVICENAME] NetworkManager[821]: <warn>  [1785492829.5888] device (wlp1s0): Activation: (wifi) association took too long, failing activation
juil. 31 12:14:14 [DEVICENAME] NetworkManager[821]: <warn>  [1785492854.1935] platform-linux: do-change-link[4]: failure 110 (Connection timed out)
juil. 31 12:14:14 [DEVICENAME] NetworkManager[821]: <warn>  [1785492854.1936] device (wlp1s0): set-hw-addr: failed to set MAC address to 2E:9A:09:49:9D:DC (scanning) (NME_UNSPEC)
juil. 31 12:14:26 [DEVICENAME] NetworkManager[821]: <warn>  [1785492866.4818] device (wlp1s0): Activation: failed for connection 'Freebox-FMG'
juil. 31 12:15:25 [DEVICENAME] NetworkManager[821]: <warn>  [1785492925.3618] platform-linux: do-change-link[4]: failure 110 (Connection timed out)
juil. 31 12:15:25 [DEVICENAME] NetworkManager[821]: <warn>  [1785492925.3619] device (wlp1s0): set-hw-addr: failed to set MAC address to D6:69:8C:08:DB:07 (scanning) (NME_UNSPEC)
juil. 31 12:16:09 [DEVICENAME] NetworkManager[821]: <warn>  [1785492969.5846] device (wlp1s0): Activation: (wifi) association took too long, failing activation
juil. 31 12:16:33 [DEVICENAME] NetworkManager[821]: <warn>  [1785492993.9699] platform-linux: do-change-link[4]: failure 110 (Connection timed out)
juil. 31 12:16:33 [DEVICENAME] NetworkManager[821]: <warn>  [1785492993.9699] device (wlp1s0): set-hw-addr: failed to set MAC address to CE:4A:48:9C:76:79 (scanning) (NME_UNSPEC)
juil. 31 12:16:46 [DEVICENAME] NetworkManager[821]: <warn>  [1785493006.2588] device (wlp1s0): Activation: failed for connection 'NUMERICABLE-FNK'
juil. 31 12:22:25 [DEVICENAME] NetworkManager[821]: <warn>  [1785493345.0219] platform-linux: do-change-link[4]: failure 1 (Operation not permitted)
juil. 31 12:22:25 [DEVICENAME] NetworkManager[821]: <warn>  [1785493345.0219] device (wlp1s0): set-hw-addr: failed to set MAC address to 32:E0:06:20:A8:71 (scanning) (NME_UNSPEC)
juil. 31 12:22:40 [DEVICENAME] systemd[1]: Stopping Network Manager...
juil. 31 12:22:40 [DEVICENAME] NetworkManager[821]: <warn>  [1785493360.1068] device (p2p-dev-wlp1s0): error setting IPv4 forwarding to '0': Resource temporarily unavailable
juil. 31 12:22:40 [DEVICENAME] systemd[1]: NetworkManager.service: Deactivated successfully.
juil. 31 12:22:40 [DEVICENAME] systemd[1]: Stopped Network Manager.
