Missing bindgenHook from rustPlatform while using in flake?
Hello there!
I’ve recently started trying to build a Rust project while on NixOS. The problem I’m having is that one of the dependencies I am wanting to use requires bindgen.
Since flakes seems to be all-the-rage lately, I’ve been using rust-overlay in my flake, and from what I can see in the manual I should be able to use rustPlatform.bindgenHook in order to overcome clang not being able to find the appropriate libraries/headers for the dependencies I am wanting to use, my flake is as follows:
  description = "Test Project";
  inputs.nixpkgs.url = "github:NixOS/nixpkgs/nixos-21.11";
  inputs.rust-overlay.url = "github:oxalica/rust-overlay";
  outputs = { self, nixpkgs, flake-utils, rust-overlay, ... }:
        overlays = [ (import rust-overlay) ];
        pkgs = import nixpkgs { inherit system overlays; };
        devShell = with pkgs; mkShell {
          buildInputs = [
            rust-bin.stable.latest.default
            openssl
            pkg-config
          LIBCLANG_PATH = "${llvmPackages.libclang.lib}/lib";
          BINDGEN_EXTRA_CLANG_ARGS = "-isystem ${llvmPackages.libclang.lib}/lib/clang/${lib.getVersion clang}/include";
This leads me to the following error though, when attempting to run nix develop:
error: attribute 'bindgenHook' missing
       at /nix/store/7s4xwp7ksrcbwn1y1nnpmnmzcz7z62c4-source/flake.nix:23:13:
           22|             pkg-config
           23|             rustPlatform.bindgenHook
           24|           ];
Every where that I’ve searched, it seems bindgenHook should still exist, but my system is unable to find it. My knowledge of Nix and Flakes is still incredibly new, so I get the feeling that I’m just overlooking something simple.
If anyone has any ideas, I’d appreciate it!
That hook did not exist in 21.11. First release I was able to find it in was 22.05.
