Missing $TEMPDIR after entering nix-shell
I have a very strange problem on a new Ubuntu 24.04 installation. I have installed nix (package manager). I use the following shell.nix file:
{ pkgs ? import  <nixpkgs> {} }:
  pkgs.mkShell {
    shellHook = ''
        echo $TEMPDIR;
        ls $TEMPDIR;
I receive the following output when using nix-shell:
/tmp/nix-shell-235409-0
<some ls files output>
The $TEMPDIR directory clearly exists when the shell is built, but it is missing afterwards!
ls $TEMPDIR
ls: cannot access '/tmp/nix-shell-235409-0': No such file or directory
This breaks many build tools as they expect the temp directory to exist.
Any idea what could be the culprit?
Edit: This might be related: `use nix` breaks `mktemp` with Nix 2.24+ on macOS · Issue #1345 · direnv/direnv · GitHub
Hello, I don’t know the culprint, but I’ve run into this myself and my workaround is to create my own temp dir and export it:
  pkgs.mkShell {
    shellHook = ''
        export TEMPDIR="$(mktemp -d /tmp/nix-shell-XXXXXX)"
then if works fine and exists after entering the shell.
