mkDerivation attribute not honored by build script?
Hello,
I am trying to cross-compile some package in my nix flake via an overlay, here is the derivation:
It is used in this output in my flake:
And the build fails with:
% nix build '.#serialosc_docker_rpi'
error: builder for '/nix/store/drsqbhnwaiqrf9vdgg1939phplbikdbd-serialosc-armv6l-unknown-linux-gnueabihf-1.4.3.drv' failed with exit code 2;
       last 10 log lines:
       >     --enable-system-libuv
       >                         use libuv
       >                         provided by
       >                         the system
       >                         instead of
       >                         the
       >                         included
       >                         git
       >                         submodule.
       > waf: error: no such option: --cross-compile
       For full logs, run 'nix log /nix/store/drsqbhnwaiqrf9vdgg1939phplbikdbd-serialosc-armv6l-unknown-linux-gnueabihf-1.4.3.drv'.
error: 1 dependencies of derivation '/nix/store/d276c73zcz3m1zrwbv6vj64yl2pn5gh2-serialosc-customisation-layer.drv' failed to build
error: 1 dependencies of derivation '/nix/store/rpniidmi0rjrl1820lrk8d6z27d4ks7y-serialosc-conf.json.drv' failed to build
error: 1 dependencies of derivation '/nix/store/0a74r99igrw7xpbcsf0wxc8f9p8wmcva-stream-serialosc.drv' failed to build
error: 1 dependencies of derivation '/nix/store/9mlbd3946kb3n1ld9hy7yydh3q6gnk8p-serialosc.tar.gz.drv' failed to build
And I fail to understand how dontAddWafCrossFlags is not expanded in wafHook.
I failed to reproduce the issue both from a vanilla flake and using flake-parts, using both nixpkgs-22.11 and my nixpkgs fork from last year that has some Python-related cross-compilation fixes (see previous discussion).
My attempt to reproduce this issue is in GitHub - lopter/badwaf: Support code to try to reproduce some nix build issue. It has two branches, one using vanilla flake and one using flake-parts.
What is going on? How does one go about debugging it?
The error is caused by the serialosc derivation, not the libmonome derivation. There is no dontAddWafCrossFlags in serialosc.nix.
Omg, thank you, I totally missed that T_T.
